  • July 13, 2025, 12:03:42 AM
Author Topic: Brodak B-40  (Read 1145 times)
Offline Al Burczycki
Brodak B-40
« on: January 13, 2011, 11:12:56 AM »
I read in one of the recent posts about the early B-40's being less powerful than later versions, and the way to tell was that the piston had half circles cut out of the piston skirt. I checked the one I have and it is the older model. While inspecting the engine further, I discovered that the piston at BDC completely masked the front and rear ports. So my guess is that relieving the piston skirt, on the later models, is the reason for the additional power. My question is, does anyone have an late model engine or piston available to confirm this, and to measure the amount of material that has been removed from the skirt? I can make an educated (?) guess, but it's always nice to know what the manufacturer did.
Offline Balsa Butcher
  • High Desert Flier
Re: Brodak B-40
« Reply #1 on: January 16, 2011, 10:53:42 AM »
Not a whole lot of responses here, possibly because many are thinking "why hack up a perfectly good Brodak 40?" The early ones still have more power than most engines in their class and more importantly, have excellent stunt-run characteristics. The muffler supplied with early ones did hve a smaller exhaust outlet than the newer ones. Find a newer muffler and use it if power  is a concern but leave the innards alone. After having said that, I have seen early B-40's w/ original muffler give excellent runs, plenty of power. I suggest breaking it it and trying it "as is" before you start modifying. Just my 2 cents.  8)
« Last Edit: January 16, 2011, 12:01:15 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Re: Brodak B-40
« Reply #2 on: January 17, 2011, 05:46:00 PM »
HI Pete,
Thanks for the input, it's what I was looking for.  I was pondering because of a thread I read here but was unable to relocate. In any case, it mentioned a difference in the old and the new B-40 power wise, and as I was cleaning the one I had,  I thought it might stir some interest to bring up the skirting issue I had noticed. Maybe I should blame it on the long Michigan winters; too much time to think. I wrote that after another 4 inches of global warming had just dumped on us, and an unknown amount of freezing rain turning to snow is forecast for tonight. Oh well, think spring.
Al B.
Offline Jim Oliver
Re: Brodak B-40
« Reply #3 on: January 18, 2011, 08:42:53 AM »
" Oh well, think spring."
Because of global warming, "spring" has been removed from the menu this year-------we will go directly to the heat of summer, with no "springtime" set aside for slow adjustment to climatic changes.  Make appropriate plans now, while there is still time. :o ::)
Jim Oliver
AMA 18475
