  • July 07, 2025, 12:55:42 PM
Author Topic: Brodak 40 with worn bushing  (Read 3261 times)
Offline Bill Barber
« on: September 05, 2010, 05:14:29 PM »
    My Brodak 40 that has run very well for the last 18 months is starting to give me fits . Inconsistent runs and gray exhaust residue are the  symptoms , the front shaft has about 1/8" play in it . Other than replacing the whole case is there another way to replace the bushing ? The motor still has good compression .
Bill  Barber
AMA 325076
Re: Brodak 40 with worn bushing
« Reply #1 on: September 05, 2010, 11:23:52 PM »
The grey is likely aluminum, probably from the backplate. Stop running it! Check inside. If it's eating the backplate, you'll burn out a lot of glowplugs. You're better off replacing the case or other needed parts, at the current price of glowplugs.
I think your 1/8" estimate is probably much exaggerated, but I'd fix it or send it to be fixed, or better yet, just buy a new one. I know they're hard to find, but sometimes they can be. Keep your old one for spare parts, just in case you (or somebody you know) needs what's left. I had two NIB, but sold them a few weeks ago.  H^^ Steve
Offline Bill Barber
« Reply #2 on: September 06, 2010, 08:25:50 AM »
   Steve , your right the 1/8" play is exaggerated but the backplate looks ok . Piston & sleeve look good and the motor had good compression so I just plan to buy a new case .
AMA 325076
Offline Bill Barber
« Reply #3 on: September 08, 2010, 08:18:33 PM »
     Just got an email from Brodak , they are out of Brodak .40 cases .  So I will have to find someone to replace the bushing .
AMA 325076
« Reply #4 on: September 08, 2010, 09:47:14 PM »
Bill...Check the crankshaft OD for out of round/taper before you get too serious about the bushing job. If the crank isn't good, the bushing doesn't matter. Were you using a shaft extension, by any chance?  ??? Steve
Offline Bill Barber
« Reply #5 on: September 08, 2010, 10:05:47 PM »
   Steve , not using a shaft extension , haven't measured  the crankshaft , but did put it a drill press and spun it .
  Crankshaft appears to be true . IIRCC other Brodak.40 users had issues with bushings wearing out .
AMA 325076
Offline dennis lipsett
« Reply #6 on: September 09, 2010, 11:46:11 AM »
Given the length of time that the Brodak 40 has been unavailable  and not privy to whats happening at the source I'd say that the Brodak 40 is in trouble. I like this engine but the supply has been choked off for over 2 years with no news from Brodak or any other source as to ever having these in stock again.I sincerely hope that they become available again because there is no comparable engine in it's price range to take it's place
Offline Bill Barber
« Reply #7 on: September 18, 2010, 08:13:09 PM »
  Had an engine builder put my Brodak -40 crankshaft on a dial indicator and found the crankshaft was machined .0035 off center .
This caused the egging of the front bushing . The con-rod at the wrist pin is also egged shaped . Steve Helmick was right , time to get a new motor .
          Bill Barber
« Last Edit: September 19, 2010, 09:22:50 PM by Bill Barber »
AMA 325076
Offline Dick Pacini
« Reply #8 on: September 18, 2010, 09:09:20 PM »
I went on the Brodak web site today and the B40 is listed as being IN STOCK! #^
AMA 62221
Offline Greg L Bahrman
« Reply #9 on: September 18, 2010, 11:02:00 PM »
 <the crankshaft was machined .0035 off center>
I heard that others have had the same problem.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Online Robert Zambelli
« Reply #10 on: September 22, 2010, 03:13:51 AM »
"the crankshaft was machined .0035 off center"
I'm not sure I understand. Off center from what? Do you mean out of round?
It's not that hard to re-bush the engine. I will do an article in the next CL World.
Offline Mike Greb
« Reply #11 on: September 22, 2010, 04:31:48 AM »
If the crankshaft was ground on a centerless grinder, it is eazy to see how the crankshaft prop shaft could be off center from the bearing area.   When the shaft is heat treated, it probably takes a bannana shape due to the timing cutout in the shaft. and on the centerless grinder it might tend to take more off the side with the timing cutout before it is ground round. If you looked at other makes of crankshafts  that were ground on a centerless grinder you would probably see the same thing.
Offline Bill Barber
« Reply #12 on: September 23, 2010, 09:23:28 AM »
   Bob if the crankshaft is off center or out of round , what is the point of putting in a new bushing ?
Won't it just wear out in a relatively short time  the new bushing ?
AMA 325076
Offline Scott B. Riese
  • Just a student of stunt
« Reply #13 on: September 23, 2010, 10:48:46 PM »
Well..I've had a few B-40 come through my shop for a new front bushing. One of them is my B-40 First Run. After about 100 runs I had about 1/4" end play on my prop...tip to tip. Taking the engine apart and noticing the front bushing is egged shaped I took the crank and my dial indicator and found that the crank not machined with the tolerances that a precision engine should be. Yes mine was out of true .0027. Some even more. Enough to cause viberation and wear.
Scott
Scott Riese
Portland, Oregon
AMA 528301
« Reply #14 on: September 24, 2010, 07:38:40 PM »
<Yes mine was out of true .0027>
I still don't understand. 1). The crankshaft is not round.   2). The crankshaft is not centered on the counterweight.  3). The propshaft is not centered on the  crankshaft......???? I guess it really doesn't matter in all cases it will be a problem and cause uneven wear on the case bearing.
Simi Valley, Ca.
« Reply #15 on: September 24, 2010, 08:03:19 PM »
3). The propshaft is not centered on the  crankshaft  H^^
Scott Riese
Portland, Oregon
AMA 528301
« Reply #16 on: September 24, 2010, 11:09:22 PM »
Thanks for clearing that up Scott...........Sounds like something that could also cause the engine bolts to loosen up or the muffler to fall off or a prop to develop fractures or even a crummy engine run due to vibration and/or foaming in the tank. Now I understand why my friend was having so much trouble with that motor.
Thanks again
Simi Valley, Ca.
« Reply #17 on: September 27, 2010, 09:48:21 AM »
Any Time Greg.  ;D
Scott Riese
Portland, Oregon
AMA 528301
