  • August 03, 2025, 03:58:53 AM
Author Topic: os max s .35  (Read 4908 times)
Offline cory colquhoun
os max s .35
« on: January 20, 2017, 12:57:42 PM »
 picked up second hand os max s .35 with wrap around muffier in ex condition,would it be good for cl stunt and what is good prop
    cory
Re: os max s .35
« Reply #1 on: January 20, 2017, 02:22:43 PM »
    cory
It's an excellent stunt engine for 500 to550 or so sq in stunt planes weighing in the neighborhood of 38 to 44 oz.
Prop would be any good wood 10-6 or APC 10-5 or 10-6.
This engine needs fuel with good lubrication from Castor and synthetic mix with minimum of 24% total oil.  Standard R/C fuel will destroy it in short order!
Re: os max s .35
« Reply #2 on: January 20, 2017, 02:37:31 PM »
Been there, done that (with a 25).  On the plus side, once you've ruined them they're very easy to flip -- it's just pointless.
« Last Edit: January 20, 2017, 03:08:28 PM by Tim Wescott »
Re: os max s .35
« Reply #3 on: January 20, 2017, 02:46:37 PM »
blank
« Last Edit: March 06, 2022, 04:15:45 PM by Motorman »
Re: os max s .35
« Reply #4 on: January 20, 2017, 11:16:08 PM »
There is a potential con rod problem but with proper lubrication they usually last for several hundred flights.  If the engine is in good condition and has very good compression I wouldn't worry about it!  This was very much a favored engine for many years in Stunt.
I have two that ran for many hundreds of flights in Noblers.  One did develop a rod problem and the rod was replaced with a ST35 rod with some minor fitting.  The ST rod is bushed.  It's a good mod for longevity if you can find a one!  I also have two so configured!
Re: os max s .35
« Reply #5 on: January 21, 2017, 08:00:10 AM »
 Hello Randy
                       What mods did you have to do to the ST.35 Rod to fit?  I have a new OS .35S and if I can find an ST.35 Rod would be doing the mod. Is there a source for the ST Rods? I have a couple of ST.35 that would benefit from new rods. I took the backplate of my engine and the rod has an oiling hole but no brass bushing. The OS.35 Combat specials were that way too.
Re: os max s .35
« Reply #6 on: January 21, 2017, 01:17:32 PM »
there is a bit of play in the shaft with no prop on it but once you install prop and nip nut virtually nothing,paid $60 bucks for it  ,i was actually thinking of building nobbler for it as i have gieske plans,but i think i will do it with profile fuse
Offline Garf
    • Hangar Flying
Re: os max s .35
« Reply #7 on: January 21, 2017, 04:05:22 PM »
The Nobler is perfect for that engine. I mix my own fuel with either 15% castor and 5% synthetic oil or 20% straight castor oil. With straight castor, it will eventually varnish up especially with a muffler. 5% nitro is usually enough unless you are at high altitude.
Re: os max s .35
« Reply #8 on: January 21, 2017, 04:19:42 PM »
blank
« Last Edit: March 06, 2022, 04:14:13 PM by Motorman »
Re: os max s .35
« Reply #9 on: January 21, 2017, 04:56:23 PM »
You don't need a Tiger rod. Go over to Stuka stunt and talk to Leonard Neumann, he makes an after market rod for that engine for about $15.
good to know thanks for the tip keen to get it in a plane runs fine on bench
Re: os max s .35
« Reply #10 on: January 21, 2017, 06:59:30 PM »
Think Newman 7 Big Art / do a Nylon T up the big end there , to hold rod fwd.
Stops it walking, also a ' X ' relief in front face , for oil retention against crank web .
A SS threadf on it , somewhere .
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=114032 ?
Re: os max s .35
« Reply #11 on: January 21, 2017, 11:25:31 PM »
Hello Motorman and Matt
                                         Gentelman I truly appreciate your help, I sent leonard a message asking for the rod and price.
