  • June 21, 2025, 10:04:14 AM
Author Topic: Brodak .40 NVA  (Read 1839 times)
Offline Gerald Schamp
Brodak .40 NVA
« on: September 23, 2018, 11:27:06 PM »
Has anyone run these NVA in other engines? Was wondering how the 2 holes in spray bar work.
Offline Reptoid
Re: Brodak .40 NVA
« Reply #1 on: September 24, 2018, 02:11:22 AM »
Several of our locals including myself have run them in OS, Magnum. and ASP engines from 25 to 46 sizes. They work excellent and I actually prefer them to others. Good design with locking collett that clamps on the smooth part of the needle valve rather than the threaded portion. They are 4mm dia. (.156")
       Don
       AMA # 3882
Re: Brodak .40 NVA
« Reply #2 on: September 24, 2018, 03:12:55 PM »
Thank you for the feedback. I have some but haven't tried them yet. Was hoping someone had tried them, they look good and should work. Haven't seen any before with the 2 holes in the spray bar. Thanks again.
Offline Christian Chacha
Re: Brodak .40 NVA
« Reply #3 on: March 11, 2021, 05:46:50 PM »
Does anyone know where I can locate a spare one. Brodak has been out of stock.
Offline Reptoid
Re: Brodak .40 NVA
« Reply #4 on: March 11, 2021, 06:30:16 PM »
When did you last check; They show extended needle, std needle, and complete assembly all in stock right now
https://brodak.com/brodak-25-40-extended-length-needle.html
       Don
       AMA # 3882
