  • June 16, 2025, 04:31:17 AM
Author Topic: OS FP .20  (Read 1791 times)
Offline jim
OS FP .20
« on: February 16, 2021, 06:22:37 PM »
Hello guy's new to the Fp .20,  I'm scratch  building a California quicker, i believe it's around a 40" wingspan, weighing in at the high twenty oz range.  Will the os Fp .20 pull this around fairly well?
Thanks Jim
Offline Geoff Goodworth
Re: OS FP .20
« Reply #1 on: February 16, 2021, 09:42:05 PM »
Should be fine.
Offline 944_Jim
Re: OS FP .20
« Reply #2 on: February 16, 2021, 10:51:24 PM »
Hi Mr. Jim,
Are you concerned the FP .20 is a little small for your plane?
Maybe we can horsetrade. I'm about to be a Veco Squaw owner, and am afraid the Magnum .25 may be a bit too big for the job. The Magnum is a full ounce heavier than the original kit's recommended Veco .29.
We can take this off forum to discuss a little deeper. If you care to consider...I'm in no rush at the moment. If you want to see my trade rep, I go by the same handle/avatar here, eBay, RCGroups, and CoxEngineForum.
Feel free to hit me up via PM to trade contact info...no commitment required. Again, consider this tire-kicking.
Jim
Offline jim
Re: OS FP .20
« Reply #3 on: February 16, 2021, 11:39:26 PM »
Well Jim i don't have another Fp .20 on hand at the moment was just looking for some info.  I do have one on a Super satan i finished recently , but have not had the chance to fly it, winter in Idaho.
https://servimg.com/view/19381305/107
https://servimg.com/view/19381305/108
Offline jim
Re: OS FP .20
« Reply #4 on: February 16, 2021, 11:43:51 PM »
Re: OS FP .20
« Reply #5 on: February 16, 2021, 11:44:49 PM »
Thanks Jim
   Very similar dimension to the Skyray 35, slap on a 9-4, adjust to peaked out lean, back off 3-6 clicks until you get a small but distinct drop in RPM, good to go. Run it STOCK, exactly as it comes from OS, no changes to anything.
Offline jim
Re: OS FP .20
« Reply #6 on: February 17, 2021, 12:12:08 AM »
Thanks Brett for your input,  will do, i'm building a SkyRay now with a Fp .25.  The Quicker should come out lighter than the Skyray i was thinking, that's why i was asking about the Fp.20. for the quicker.
