  • June 20, 2025, 06:07:29 PM
Author Topic: Brodak .40 dimensions  (Read 1553 times)
« on: October 09, 2006, 08:20:15 AM »
Does the Brodak .40 have the same mounting dimensions and length as a Fox .35 so it could be a direct swap with no mods to the model? The length is also important to me in this case, because of built in spinner gap spacing on the model.
Thanks!
Offline Ralph Wenzel (d)
Re: Brodak .40 dimensions
« Reply #1 on: October 09, 2006, 09:17:24 AM »
The simple answer is "No".  If you want a drop-in for the Fox, I believe a Double Star .40 is the only way to go. The Brodak was designed to be a drop-in for the OS Max .35S.
Ralph Wenzel
AMA 495785 League City, TX
« Reply #2 on: October 09, 2006, 11:58:03 AM »
Thanks Ralph. I knew the Double Star would go, but wasn't sure on the Brodak. Didn't know the Brodak was the same as the OS-S though-good info! ;D
« Reply #3 on: October 11, 2006, 07:46:36 AM »
The Brodak has a longer nose.  ;D
Bill <><
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #4 on: October 11, 2006, 11:22:45 AM »
Just to summarize, I removed an OS 35S from my built up fuse Omnium and dropped in a Brodak 40, the needle valve was off by about 1/16th, other than that it was a perfect fit.
