Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 15, 2025, 03:43:01 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Brodak .40 dimensions
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Brodak .40 dimensions (Read 1538 times)
wwwarbird
2016 supporter
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
on:
October 09, 2006, 08:20:15 AM »
Does the Brodak .40 have the same mounting dimensions and length as a Fox .35 so it could be a direct swap with no mods to the model? The length is also important to me in this case, because of built in spinner gap spacing on the model.
Thanks!
Logged
Ralph Wenzel (d)
Trade Count:
0
Captain
Re: Brodak .40 dimensions
Reply #1 on:
October 09, 2006, 09:17:24 AM »
The simple answer is "No". If you want a drop-in for the Fox, I believe a Double Star .40 is the only way to go. The Brodak was designed to be a drop-in for the OS Max .35S.
Logged
Ralph Wenzel
AMA 495785 League City, TX
wwwarbird
2016 supporter
Trade Count:
0
Admiral
Reply #2 on:
October 09, 2006, 11:58:03 AM »
Thanks Ralph. I knew the Double Star would go, but wasn't sure on the Brodak. Didn't know the Brodak was the same as the OS-S though-good info!
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Reply #3 on:
October 11, 2006, 07:46:36 AM »
The Brodak has a longer nose.
Bill <><
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Bob Reeves
2016 supporter
Trade Count:
0
Admiral
Reply #4 on:
October 11, 2006, 11:22:45 AM »
Just to summarize, I removed an OS 35S from my built up fuse Omnium and dropped in a Brodak 40, the needle valve was off by about 1/16th, other than that it was a perfect fit.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
