  • June 20, 2025, 02:39:38 AM
Author Topic: New Aeropipes?  (Read 1922 times)
Offline peabody
New Aeropipes?
« on: September 10, 2006, 05:29:23 AM »
I got an e-mail from Randy indicating that he has a new line of pipes....maybe he'll explain....
Re: New Aeropipes?
« Reply #1 on: September 10, 2006, 01:36:06 PM »
Hello Everyone, Hi Rich
I now have  full stock of  all 2007 model Aero Pipes, Improvements  included  all versions being the new  HI Torque Designs, The PIPES  are all  Very High quality 100% Carbon weave with  Double locked baffles and cones, New 2007 Higher temp resins, and  fully heat cycled in Lab ovens to assure  quality and  the highest temp resistances, CNC baffles, and  aluminum Conical tail pieces, I have found the conical tail cone works better than a flat one. these are  also available  in a  Carbon back. Many new products are coming online, and I am manufacturing the pipes here at my shop, so there will be  no more  delays in pipes production.
sizes are  40-50  ,  55-65  , 65-75,   and the 75-85  pipe.
Randy Smith
Re: New Aeropipes?
« Reply #2 on: September 10, 2006, 09:50:08 PM »
Hi Randy,
Will the pipes be available with the built in "stinger" (kick down)??
Bill <><
Re: New Aeropipes?
« Reply #3 on: September 11, 2006, 09:31:25 PM »
Hi Randy,
Bill <><
Hi Bill
Not Yet , I do have a lighter  silicone  divertor I am using, so there is little  need  for the  angled ones
Re: New Aeropipes?
« Reply #4 on: September 11, 2006, 09:35:28 PM »
Thanks, Randy.
Bill <><
Offline Dennis Vander Kuur
Re: New Aeropipes?
« Reply #5 on: September 12, 2006, 09:23:01 AM »
Randy,
I am planning on getting a PA .65 for use in a Brodak Legacy. On your web site you list three different pipes for the PA.65 (i.e. CF55-65- Chambered "HI Torque", CF65-75 CF Pipe for 65's - 75's New " Hi-torque", and CF-65-75 Chambered Long pipe "New Ultra Torque"). To help me decide which one to get, could you please explain the difference between the 3 pipes? Many thanks for your help.
Dennis
Dennis L. Vander Kuur
AMA 29292
Re: New Aeropipes?
« Reply #6 on: September 12, 2006, 11:01:09 AM »
Randy,
Dennis
Hi Dennis
There are as of now  only 2 pipes for the 65, The recommended  pipe  is  the  65-75 HI Torque. it is 1.6 inches maximun diameter, the other  slim  line pipe is the 55-65  pipe, it is for planes that cannot hold a 1.6 inch dia  pipe.
Re: New Aeropipes?
« Reply #7 on: September 12, 2006, 11:55:59 AM »
Randy,
Thank you for the quick reply and good information.
Best regards,
Dennis
AMA 29292
