  • June 18, 2025, 09:22:38 PM
Author Topic: Cox 09 spray removel  (Read 1014 times)
Offline Bootlegger
« on: August 11, 2020, 10:14:48 AM »
 Fellow modelers,  what is the best/proper way to remove the spray bar from a Cox 09 engine, and of course the proper way to re-install it..  thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline kenneth cook
Re: Cox 09 spray removel
« Reply #1 on: August 12, 2020, 01:28:27 PM »
           You put the engine in a clear plastic bag, you remove the E-clip that retains it within the bag so you don't lose it. Then you push it out. It's probably glued in from castor, a little heat from a heat gun will assist.
« Reply #2 on: August 31, 2020, 12:06:05 AM »
TeeDee or Medallion?  D>K Steve
Offline Bootlegger
« Reply #3 on: August 31, 2020, 06:31:58 PM »
 My bad, it is a medallion, and I'm obliged to everyone for the help... D>K   #^
Gil Causey
AMA# 6964
