  • June 20, 2025, 07:03:33 PM
Author Topic: Merco 35 Head Gasket replacement.  (Read 2351 times)
Offline Chris Wilson
« on: January 24, 2013, 06:28:52 PM »
Hi all,
I am looking for an alloy replacement for the fibre head gasket on my Merco 35.
The I.D. is 20mm and the O.D. is 24 but anything with a 20mm I.D. would be fine.
I know, I can make one but if there is something out there that I can use I will use it.
Thanks.
MAAA AUS 73427
Offline Al Burczycki
Re: Merco 35 Head Gasket replacement.
« Reply #1 on: January 25, 2013, 10:09:19 AM »
Hi Chris,   I use the universal head gasket, the Fox 35. It fits nearly all 35's and will fit the Merco 35. It actually works better than the fiber one as it will transfer heat better, and the head is removable without damage to the gasket.
Al Burczycki
« Reply #2 on: January 27, 2013, 02:20:27 PM »
Al Burczycki
Al, thanks for the help here.
MAAA AUS 73427
Offline Lauri Malila
« Reply #3 on: January 27, 2013, 03:19:29 PM »
Hi. With a lathe & some sharp tools, shims are easy to make. (They don't have to be as complicated as the ones in pictures :))
Just stack pieces of shim stock with cyano and have some fun with lathe. Then dissolve the cyano in acetone. L
« Reply #4 on: January 27, 2013, 04:01:33 PM »
Hi Lauri,
            a lathe is a useful tool but if you don't have one the most useful tool sometimes is a Visa card!
(Nice work as usual mate.)
Cheers. :)
MAAA AUS 73427
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
« Reply #5 on: January 30, 2013, 02:50:35 PM »
I'd use the original one as a template and make a couple out of copper foil. Then put one either side of the original gasket, and use all three! - I know this sounds like a bit of a botch job, but I did it on my Fox 36X and it runs better than ever (after some correct tightening of the headbolts:-).
« Reply #6 on: January 30, 2013, 03:01:38 PM »
Hi Tim,
          ever try pulling a gummed up 40 year old fibre gasket out of a tight fitting channeled groove?
You won't get it out undamaged and indeed mine came away after 3 days soaking in kero, judicious levering with a jewelers screw driver and in more than 7 different pieces and strips.
Anyway, Randy Smith is on the job and hopefully some Fox 35 ones will fit.
Thanks.
MAAA AUS 73427
« Reply #7 on: March 05, 2013, 04:06:27 PM »
Enya 35 head gaskets fit a Merco 35 perfectly.
MAAA AUS 73427
Offline rustler
« Reply #8 on: March 06, 2013, 02:17:01 PM »
Some folks lap the top of the cylinder to make sure it's dead flat, then lap the head to the cylinder. Then fit whatever gasket.
Copper sounds good, will probably "distort" to accommodate any slight irregularities without any lapping.
Ian Russell.
« Reply #9 on: March 06, 2013, 02:51:23 PM »
Hi Ian,
          glad that you chimed in here.
Lapping sounds good as the gasket is aluminum not copper.
I have reassembled the head, dunked it inverted in a glass jar full of kero and brought it up to compression  - no bubbles detected so I guess that it has no leaks.
I have got Herb Hanna looking at it when finished so I can't go too far wrong mate.
Cheers.
MAAA AUS 73427
