  • June 18, 2025, 04:02:05 PM
Author Topic: Brodak 15  (Read 2852 times)
Offline John Skukalek
Brodak 15
« on: June 26, 2021, 12:15:39 PM »
Is the Brodak 15 that is currently available a good motor?
Re: Brodak 15
« Reply #1 on: June 26, 2021, 12:28:37 PM »
Depends on what you are going to do with it.  For all round sport flying it is great.  Broken in correctly is is a decent stunt engine.  Not a power house for speed or racing or even carrier. D>K
Re: Brodak 15
« Reply #2 on: June 26, 2021, 05:55:22 PM »
Thanks for your replies john and Motorman. I think i'll give it a try in a trainer for my 6 yr old grandson.
Offline Robert Zambelli
Re: Brodak 15
« Reply #3 on: July 01, 2021, 07:19:16 PM »
The Brodak 15 is a very nice all-around stunt/sport engine.
When I wrote the operating instructions, I made an error in the fuel requirements.
I mentioned 5 to 15% nitro - you can, in fact, go as high as 25% nitro without any issues.
Do not run straight castor - a good oil blend is 50/50 castor/synthetic but the engine seems happier with less castor and more synthetic. 30/70 is fine.
Don't look for a 2/4 break - it won't happen unless you lower the compression with an extra head shim or two. That will cost you some power.
Keep in mind however that the engine was designed to run on the lean side and in the tests I've run, that's where it performs best.
Experiment with different props in the 7 to 8 inch diameter range and different pitches to see what works best for you.
I've had very good results with the 8-6 Top-Flite wood.
The break-in time varies. After around 20 minutes total time, slowly lean it out until it stops. If it stops abruptly (like seizing), it needs more time. If it just leans out and dies, it's ready to fly.
Re: Brodak 15
« Reply #4 on: July 09, 2021, 08:58:13 PM »
Thank you for that information Bob. What total % of oil do you recommend?
Re: Brodak 15
« Reply #5 on: July 10, 2021, 01:33:59 PM »
Hi, John.
22 to 23 % total oil will do just fine.
I've used the Brodak 10-23, 50/50 since the engine was new.
Powermaster is excellent also.
Re: Brodak 15
« Reply #6 on: February 05, 2022, 10:02:36 PM »
I recently purchased a Brodak 15 CL engine. Can someone tell me if a long glow plug such as a SIG GP003 RC long with idle bar can be used  or does it require a short glow plug?
Re: Brodak 15
« Reply #7 on: February 06, 2022, 05:56:34 AM »
Long reach.
I have never needed an idle bar plug so I cannot comment on the performance.
If you do use one, make sure there is no interference at top dead center.
Re: Brodak 15
« Reply #8 on: February 06, 2022, 07:20:47 AM »
Thanks Bob. To confirm, you are saying that a long plug will work but you're not sure if one with an idle bar will interfere with the piston?
Re: Brodak 15
« Reply #9 on: February 06, 2022, 07:57:41 AM »
I take it the instructions have not been read. mw~ S?P H^^
Re: Brodak 15
« Reply #10 on: February 06, 2022, 09:13:42 AM »
    Easy way to check is to take the head off and run a plug with gasket washer into the hole and see what it looks like. The end of the the threads should be flush with the surface in side the head. If the threads are too long it will, of course protrude below that. if too short you will see female threads.
« Last Edit: February 06, 2022, 10:54:38 AM by Dan McEntee »
Re: Brodak 15
« Reply #11 on: February 06, 2022, 02:55:19 PM »
Thanks for the help everyone.
