As many of you know, I have been working with John on the development of the small engines.
Whenever an engine fails to meet customer expectations, it is sent to me for evaluation.
Aside from a very few instances, every allegedly defective engine proved to be in perfect working order.
They started easily and ran smoothly.
A number of customers confessed that they DID NOT read the instructions.
I spent a lot of time writing the operating instructions and, if followed, the engine should work exactly as intended.
A few hints for initial break-in:
DO NOT USE more than 10% nitro or less than 22% oil (50/50).
Use a 6-3 or 6-4 nylon propeller
If the engine will not draw fuel, insure that the spray bar hole is oriented downward.
And, again I state - READ THE DIRECTIONS COMPLETELY before attempting to run the engine.
Feel free to call or e-mail me and I will help as much as I can.
If I receive an engine and it is indeed defective, it WILL BE REPLACED!!
