  • June 28, 2025, 07:33:33 AM
Author Topic: Brodak .049 - PLEASE READ!!!!!  (Read 1263 times)
Offline Bob Zambelli
« on: February 13, 2007, 09:13:53 AM »
As many of you know, I have been working with John on the development of the small engines.
Whenever an engine fails to meet customer expectations, it is sent to me for evaluation.
Aside from a very few instances, every allegedly defective engine proved to be in perfect working order.
They started easily and ran smoothly.  #^ #^
A number of customers confessed that they DID NOT read the instructions.  HB~>
I spent a lot of time writing the operating instructions and, if followed, the engine should work exactly as intended.
A few hints for initial break-in:
   DO NOT USE more than 10% nitro or less than 22% oil (50/50).  n1
   Use a 6-3 or 6-4 nylon propeller  y1
   If the engine will not draw fuel, insure that the spray bar hole is oriented downward.
And, again I state - READ THE DIRECTIONS COMPLETELY before attempting to run the engine.
Feel free to call or e-mail me and I will help as much as I can.
If I receive an engine and it is indeed defective, it WILL BE REPLACED!!   ;D ;D
Re: Brodak .049 - PLEASE READ!!!!!
« Reply #1 on: February 13, 2007, 01:23:26 PM »
Great Advice!!
Please read the manufacture's instruction sheet for info on, how to break-in the motor, what fuel is recomended , and proper running tips
.......that is if all else fails.....  y1    HB~>
« Last Edit: February 13, 2007, 07:52:45 PM by RandySmith »
Offline Ralph Wenzel (d)
« Reply #2 on: February 13, 2007, 03:42:16 PM »
A big 10-4 on all the above, Bob. In the computer industry, it goes "RTFM"!
Ralph Wenzel
AMA 495785 League City, TX
« Reply #3 on: February 13, 2007, 04:39:41 PM »
Great Advice!!
Please read the manufacture's instruction sheet for info on, how breakin the motor, what fuel is recomended , and proper running tips
Or............ you can just do like I do and call you up!!!!  **) **)
(Randy is on my "speed dial list"!)
Offline Douglas Babb
  • What goes through your mind first as a line breaks?
« Reply #4 on: February 13, 2007, 05:58:51 PM »
WE DON' NEED NO STINKIN 'STRUCTIONS, DUZ WE? In all seriousness these are definitely a different animal. If you only had Cox engines and feel life begins at 25% nitro, this is not the engine. Jus' jerkin yer chain Bob. >:D H^^ **)
Offline Vincent Corwell
« Reply #5 on: February 14, 2007, 01:23:02 AM »
Bob Z:
If you see the tiny percentage of sales numbers that come back
as complaints , you must need little time to deal with them!
As an aside I still dont see the MK II Brodak 049 on the web site
and where we fly the silcencer would be needed, what one will fit
please?
Appreciate any reply
Vincent
« Reply #6 on: February 14, 2007, 02:13:18 AM »
All Bob is saying, Vincent, is that if folks followed the instructions, even the current small number of complaints would be even further reduced- - - RTFM
Ralph Wenzel
