use muffler pressure or not, Hi All, I've had this SC 25 for a few years now, never used it before but its going in a Flite Streak which has a standard wedge tank (one pipe up and one pipe down plus the feed) I don't know if these motors run better with a muffler pressure pipe.. This plane weighs 29 oz, do you think a 9x6 prop is the right size? I'm thinking it might be quick! Thanks Phil
