  • June 19, 2025, 12:29:43 AM
Author Topic: Speeds up in eights  (Read 902 times)
Speeds up in eights
« on: September 18, 2018, 05:37:46 PM »
So, now my airplane is speeding up in the outside portion of the horizontal eights -- but not the outside rounds, or the outside parts of the vertical or overhead eights, or the clover.  And it's going screaming lean, too -- it's not just speeding up a subtle little bit.
I did notice after my last flight yesterday that the engine was loose, so I'm willing to believe that's it, but I'd like to show up at the field with other possible things to look into if it's still doing it now that the engine is tight.
Re: Speeds up in eights
« Reply #1 on: September 18, 2018, 06:58:32 PM »
Why is the engine getting loose??  Out of balance prop/spinner?  Over stretched mounting bolts??   D>K
Really screwy mounting system because the engine's mounting holes are narrower than what the plane came with.  I really, really, don't want this to become a "how to mount an engine" thread, because I have that straightened out for now (I had the engine out over the weekend, and swapped a couple of parts of the screwy mounting system putting it back together.  It's fine now).
It may or may not have been doing it at the last contest I was at, but it's hard to tell because I had tank problems at the contest.
My plan is to go fly, and if it's fine now that the engine is nailed down correctly declare victory.  But if it isn't, I'd like to have things I can check either before I go, or in the field.
