  • August 03, 2025, 08:44:27 PM
Author Topic: Who Can Rebush Conrods?  (Read 1912 times)
Offline Dallas Healey
« on: September 08, 2009, 04:58:05 AM »
Can anybody recommend somebody, either is Australia or the USA, who can rebush conrods? I have an old OS 29 twin stack and two old Super Tigres (51 & 40) that are worn in the big end.
Offline Ward Van Duzer
Re: Who Can Rebush Conrods?
« Reply #1 on: September 09, 2009, 09:22:55 AM »
There was a company called "RPM" (or R.P.M.) that manufactured bushed con rods for our engines. Mebee a search will turn up something...
W.
Alan Hahn
« Reply #2 on: September 09, 2009, 02:02:28 PM »
I would worry that when worn out, the supporting structure might also be compromised (e.g. worn too). So there may be a strength issue.
« Reply #3 on: September 10, 2009, 02:44:22 PM »
RPM used to make NEW ones!
W.
Offline Jim Scott
« Reply #4 on: September 11, 2009, 08:44:59 AM »
You might try Mattes Engine Rework.  This is a site I happened across but have no experience with their work.  If they can help you out, please post result here.
Jim
http://www.flyfreeflight.com/Site/Welcome.html
« Reply #5 on: September 11, 2009, 01:31:33 PM »
Dallas
Most anyone who has a small lathe can make a bushing for you, Get SAE 660 bronze, or Phosphor bronze or use a automotive bronze valve guide, You may need to buy a reamer or 2 sized near what you are working on.
Offline Geoff Goodworth
« Reply #6 on: September 13, 2009, 03:13:04 AM »
Dallas
I suggest that you talk to Herb Hanna, (Dallas Hanna) or John Goodwin (raglafart) on the forums.
Cheers, Geoff
« Last Edit: September 19, 2009, 04:57:11 PM by Geoff Goodworth »
Offline Clancy Arnold
« Reply #7 on: September 13, 2009, 03:47:03 PM »
The first name that comes to mind is Bill Gruby, Master Machinist.
He just had surgery, but should be recovering soon.  We all hope.
Clancy
Clancy Arnold
U/Tronics Control
Offline Bill Gruby
« Reply #8 on: September 13, 2009, 05:55:23 PM »
 Thanx Clancy;
  You make me blush.
  They can be rebushed without too much trouble. The problem comes if they are worn out to one spot on their circumferance. If this has happened I have to agree with Allen, their strength has been compromised. In that case the lesser of two evils is to make a new rod. Randy is correct 660 Bronze is the stuff to use.
 A good drill press and a dedicated jig and anyone can bush a rod, it is not rocket science. A lathe is better and a mill better yet.
 My preferance would be a new rod, don't mess with the old ones.
  "Billy G"  H^^
Bill Gruby
AMA 94433
MECA 5393-10
Offline Leo Mehl
« Reply #9 on: September 18, 2009, 08:37:55 PM »
Thanx Clancy;
  You make me blush.
  "Billy G"  H^^
Billy boy, have they fixed whats wrong with you yet or are they too late. Maybe an erector set would be in order. LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ HB~> HB~>
Offline Bill Gruby
« Reply #10 on: September 19, 2009, 05:48:18 AM »
 Hi Leo,
  Don't need to fix me, I'm already bushed.   VD~ VD~ VD~ LL~ LL~ LL~
  "Billy G"   S?P
Bill Gruby
AMA 94433
MECA 5393-10
