  • June 26, 2025, 01:56:52 AM
Author Topic: breaking to hard la46  (Read 1524 times)
Offline Ron Hess Sr
« on: September 18, 2011, 10:25:35 AM »
I have a os la 46 and the break is to strong,it comes on @8 and stays on until level again? suggestions on how to 4/cycle more. Thank you. Ron.     here is the setup.
11.5x4 apc -T.bolt plug. metal backplate.
10/22 powermaster 1/2-1/2.
.282 venturi and ST.nva and 1-head gasket.
scott dinger muffler with no pressure.
B.line air filter with green screen.
6.oz uniflo tank.
Offline Bootlegger
Re: breaking to hard la46
« Reply #1 on: September 18, 2011, 10:44:36 AM »
Ron, some of the things that we have done is reduce the "squish band" to about 1/2 half the size that it is.
 Original is about 3/16" so 3/32" is about half, or add a couple extra head shims (gaskets), we also are using a venturi of .275 down to about .262.
 One of the way's that we get the venturi size reduced is to J B weld (Metal filled epoxy) the venturi closed, then drill it out, or get with Jim Lee (vendors section) for venturi's.
 Add about 2 oz extra castor oil to fuel, and we also are turning APC props that measure 12x5..
  Hope that this helps...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Andrew Tinsley
« Reply #2 on: September 18, 2011, 01:51:48 PM »
Hello Ron,
  LA46s seem to run much better in a constant 2 stroke. Although I have seen 4-2-4 runs, they are much better at a constant 2. Try it, you may find you like it.
Andrew.
BMFA Number 64862
« Reply #3 on: September 18, 2011, 01:59:17 PM »
we have had much better success with them running a fat two cycle as well, about 9800 rpm with the APC 12.25 x 3.75
« Reply #4 on: September 27, 2011, 10:32:30 AM »
Hi Ron,
I replied in the other thread about this, but I agree..... a "wet 2 and a low pitch prop.  More power, less fuel, excellent, consistent runs.  The stock timing and set up just doesn't really "like" a 4-2 style run.
Big Bear
Offline gwassenaar
« Reply #5 on: November 02, 2011, 03:15:29 AM »
Please help me out of my misery?Could posters in this thread please specify their choice of glow plug? I am now wondering what the effect of plug choice is on the performance.
For instance, I have my LA 46 engine on a normal front NVA, Aluminum backplate, a reduced squish band, 5% Nitro, 20% Castor,
 AND an Enya 3 plug.
 And I use a Scott Dinger muffler. The engine will turn a 12x4 wood(Zinger) or the special APC 12.25X 5.75.
« Reply #6 on: November 02, 2011, 10:01:12 AM »
6.oz uniflo tank.
    There should be no "breaking" in the first place. Reduce the pitch and increase the RPM until you get it running in a rich to medium 2-stroke. IT cam be modified to run in a 4 and do a 4-2 break but that gives up A LOT of the available performance.
« Reply #7 on: November 23, 2011, 08:19:20 PM »
That's what I thought. Kind of like trying to run an FP 40 on an 11x6, it'd run away for sure. Put an 11x4 on it and it was rock steady.
