  • June 25, 2025, 06:06:00 PM
Author Topic: Enya 40XZS with Warden Continental  (Read 1618 times)
Online Steve Thomas
« on: September 05, 2011, 05:46:07 PM »
I'm just about to start on a Continental (the Bill Sawyer 'Laser Continental' kit).  I was originally going to use something like an old Enya 45-I in it, but I just realised I've got a shiny, new, barely-run-in 40XZS just sitting in a box doing nothing.  Has anyone got any thoughts on using the 40 in a model this size (55" span, 570 sq.in)?  I suspect the 40XZS is just as strong as the old .45, and has the further advantage of a 1/4-28 shaft versus the M7 one on the .45 (a minor issue involving a really cool needle-nose spinner I want to use).
Cheers
Offline Balsa Butcher
  • High Desert Flier
Re: Enya 40XZS with Warden Continental
« Reply #1 on: September 05, 2011, 06:19:36 PM »
Use the XZS, use ths XZS use the XZS, did I mention that I recommend using the ENYA 40 XZS? This is an awesome motor, just got through running mine in preparation for its installation in a Shark 35. Further recommendation: Get one of Randy's tube mufflers for it and use the additional head gasket that's in the box. This is  an under rated motor and worth its premium price. It appears to be a solid, strong, incredibly smooth 4x2x4 motor, not a 2 cycle screamer. It will have plenty of power for the Laser Continental. 8)
***Observations based on bench runs - flight tests to follow.
« Last Edit: September 05, 2011, 06:48:33 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Online Steve Thomas
« Reply #2 on: September 05, 2011, 07:33:26 PM »
Thanks Pete, I sense that you have a slight leaning towards the 40XZS. ;D  Looks like that's the way to go, not that I needed much convincing.  Like you, I've only bench-run mine, but was most impressed.  A very classy engine, as my friend who distributes/collects/fixes/designs/builds engines put it.
How much difference did the extra head gasket make?
  • High Desert Flier
« Reply #3 on: September 05, 2011, 09:26:47 PM »
The second head gasket softened the transition between 4 cycle and 2 cycle. You may prefer to run it with one head gasket to start with. The second can always be added later. Since the Shark 35 is small (and hopefully light) for this engine I just added it from the start. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Paul Allen
« Reply #4 on: September 06, 2011, 02:34:33 AM »
        I have run the 40XZS in an Oriental, 55in span ( 550 sq in ), motor ran well after a bit of sorting.
Found it was overcooling with the head stuck out in the breeze in the Oriental,may not be a problem with a full
cowl,5% nitro, 23% oil,( 50/50 Klotz & Castor ) stock motor as it came out of the box with a Glow Devil 300 plug,
RSM T/Muffler, APC 11x4, RPM on ground  9,900 to 10,000, used 95cc of fuel for a 6min 30sec flight ( FAI rules).
The thing that brought it to life was using the APC 11x4 prop.Uniflow tank( No muffler pressure, but has a restrictor
on the uniflow vent) motor was riching up at the end of the flight,the restrictor solved this.
Paul Allen
OZ
Offline Jim z
« Reply #5 on: September 06, 2011, 06:44:34 PM »
Steve,
 use the  enya 40 xzs.  I have a couple of these and they are well
worth the cost.  They are extremely smooth and powerful.
I run mine with the one head gasket,  7 1/2 % nitro  1/2 castor 1/2 synthetic,
11x5 zinger and Brodak props, uniflow tank.  Nice 4-2-4 break.
 No need for rework of any kind.
Offline Chris Wilson
« Reply #6 on: September 11, 2011, 05:18:52 PM »
Found it was overcooling with the head stuck out in the breeze in the Oriental ........
Paul Allen
OZ
Quick and dirty fix for a suspected over cooled engine - just roll some O rings down the barrel to block the air from flowing over and through the fins.
Infinitely adjustable and cheap with permanent modifications anywhere!
Cheers.
MAAA AUS 73427
