Hi all -
Some may have searched, as I have, for data on no nitro compared to some nitro in various engines.
I didn't set out to do a rigorous test sequence, so I'm simply offering results as noted on the bench from some of my engines.
These pretty well run the gamut of c/r and technologies for plain-bearing sport engines.
Strictly empirical of course, but I selected common points. YMMV.
These engines were run during the past year or so, different days, temps, humidity, only 690' ASL and my old Carl Goldberg test stand clamped to the porch rail were the same.
Fuel even varied +/- 1%ish, in 16 oz batches, as I remix Morgan's 15% for ~9% nitro, adding straight castor to 25%; I mix locally obtained methanol and straight castor for 0%.
I've had no problem with starting either mix.
I make no recommendation for any particular mix; you may well have particular requirements.
Factors other than rpm certainly enter into that selection.
I hope you find it at least interesting, maybe even useful.
regards,
Terry
Nitro/Meth/Oil
0/75/25 9/64/25
Veco .19
8-4 MAS 14.5 15.0K
8-5 APC 13.3K 13.8K
9-4 APC 11.4K 12.0K
OS .20FP steel
9-4 Zngr 12.6K (n/r) (not run)
9-6 MAS 9.9K (n/r)
note: I do fly these OS .20s on 9% fuel.
OS .20FP ABN
8-4 APC 13.1K (n/r)
O&R .23
#1 #2 #1 #2
9-4 APC 11.8K 11.6K 12.1K 11.9K
9-6 APC 10.2K 10.4K 10.7K (n/r)
OS .25FP ABN
9-4 APC 13.7K 15.0K
10-4 Zngr 11.0K 11.7K
McCoy .29 1952
9-4 Zngr 8.5K 8.5K
Enya .35-III B
10-4 Zngr 11.5K 11.7K
10-6 MAS 10.6K 10.8K
OS .46LA
11.5-4 APC 10.4K 10.8K
12.25-3.75 APC 10.1K 10.4K
