  • June 21, 2025, 08:15:53 AM
Author Topic: RoJett port timing  (Read 1150 times)
steven yampolsky
RoJett port timing
« on: June 10, 2007, 09:11:30 PM »
What is the port timing for the RoJett's? I am trying to get a pipe length for a RoJett51 from Randy's pipe chart.
Offline Ron Merrill
Re: RoJett port timing
« Reply #1 on: June 11, 2007, 01:57:23 PM »
Steve, check with Rich or Dubb direct. Ron.
« Reply #2 on: June 11, 2007, 03:41:13 PM »
Hi Steven
You cannot set it by what my chart says for PAs  because  the timings on Jett engines have been differant.
Best thing is to check your particular motor your self, or  call Jett  and  ask, if you do neither  use  the  chart  at the  145 degree setting,
steven yampolsky
« Reply #3 on: June 12, 2007, 08:57:11 AM »
Thank you Randy! Your pipe chart is one EXCELLENT tool!
