  • July 03, 2025, 10:33:56 PM
Author Topic: Break in procedure for true ABC engines  (Read 1406 times)
Offline Geoff Goodworth
« on: January 02, 2018, 12:40:25 PM »
Hi folks, happy New Year
I have a NIB Tower 40 that I want to break in and use.
Should I use a break in procedure like the Brodak 40—multiple short runs and allow to cool in between—or is there another preferred approach?
Re: Break in procedure for true ABC engines
« Reply #1 on: January 02, 2018, 04:24:43 PM »
  That would be as good a place to start as any. I would bolt up a 10-4 prop and do the 2 minute routine, and after a dozen cycles or see see how it runs with a 11-4 and reacts to the fuel line pinch test. The Tower .40 is a true ABC I believe and is a pretty long lasting engine. A local guy had one in a Tucker Special and after several seasons of running, he had an issue where the main bearing varnished up and caused some issue. The only time I have ever heard of any one having a problem with a Tower.40 We took it apart, cleaned up the shaft and bearing and all was well.
Offline Brian Gardner
« Reply #2 on: January 02, 2018, 04:44:28 PM »
Run it warm up on the 4/2 switch. Not cold/wet/rich 4 cycle only. Multiple short runs to heat cycle the materials to start with and then some longer stuff.
By the way Geoff I'm doing a run of FP40 sets (interchangible with the tower) that are stunt timed etc.
Happy new year mate.
Brian
