  • June 20, 2025, 10:32:39 PM
Author Topic: Bratt Engines  (Read 1460 times)
Bratt Engines
« on: August 30, 2014, 08:22:27 PM »
   I just acquired an engine that is a Bratt brand, and .28 displacement. I remember reading on the other forum that Iskandar Taib use to use these for speed limit combat years ago because they were inexpensive and ran well.. They were put out by World Engines. Anybody else have any experience with these? It's looks like a nice little engine, ball bearing, nice carb casting quality looks decent. I'll probably get a verturi for it and see if it will run well in a wet two stroke and use it for a sport stunt engine.
  Thanks in advance for any insight.
   Type  at you later,
Re: Bratt Engines
« Reply #1 on: August 31, 2014, 06:37:44 AM »
I would pull the back plate and check the rod fit then flush it out with wd40.
Offline Brian Hampton
Re: Bratt Engines
« Reply #2 on: August 31, 2014, 09:04:21 AM »
These are actually the Bluebird engines made in Taiwan but were sold in America as Bratt (no idea why). The 21, 25,28 and 45 are all AAC while the 51 is ABC. I have a 28 and 51 (both new when I got them) but have only run them on the test stand. Their finish both inside and out is quite impressive, in fact the 51 reminds me very much of my Rossi 45 and actually out turned the Rossi one day on a back to back test.
Re: Bratt Engines
« Reply #3 on: September 20, 2014, 07:52:23 PM »
The Brat 28 I had, quite a number of years ago, had an ABC P/L.  It ran just fine at reasonable rpms.  Trying to get the most out of it with a wide open venturi and a smaller prop, it broke the shaft after 3-4 runs.
