  • June 21, 2025, 01:35:29 AM
Author Topic: Bolly EQ62 (narrow) pipe  (Read 1722 times)
Offline Andrew Tinsley
« on: August 25, 2013, 12:56:00 PM »
Hello Everyone.
 I was wandering around our famous National swop meet this morning and took a  chance on a brand new Bolly EQ 62 (narrow) carbon fiber pipe. It looked as though it may be useful for a stunt pipe. Anyone know if it is any good for stunt and if so what size engine (Maybe 60 size)?
  At $15 I have not lost a lot and maybe I did get a bargain! If it is useful for stunt, it may take a season or two to sort it out if it isn't one of the well known pipes!
More in hope...............
Andrew.
BMFA Number 64862
Re: Bolly EQ62 (narrow) pipe
« Reply #1 on: August 25, 2013, 02:59:27 PM »
Hi again Andrew.  You may have a good pipe (or not).  Some pipes used fiberglass/epoxy.  These don't last long because of hot spots.  CF pipes are the best, and heat-proof.
I have a new pipe made of fiberglass.  I don't expect it to last long.  When it goes, I will get a real pipe from Aero Prod. or such.
floyd in Oregon
Offline Brian Hampton
« Reply #2 on: August 25, 2013, 07:09:19 PM »
Hi Andrew, I think you got a good deal there because Bolly pipes were about on a par with Eather pipes. Also they were made here in Adelaide. There's a spec sheet for all Bolly pipes at www.bolly.com.au/book/Book.php?Chapter=7&Section=3 or go to http://www.bolly.com.au/book/content.html for the complete book.
Cheque still not cashed BTW :).
« Reply #3 on: August 26, 2013, 05:58:57 AM »
Thanks Floyd and Brian,
The said pipe appears to be epoxy and carbon fiber, so maybe I struck lucky. The pipe is listed in the Bolly book and is recommended for stunt with a launch rpm of around 10,000.
It would be interesting to hear what sort of engine it was used fro. Certainly about .60 for an f3b pattern ship, but F2b? I have an OS 46 VF doing nothing maybe I could use that?
Andrew.
BMFA Number 64862
« Reply #4 on: August 26, 2013, 08:23:12 AM »
Andrew.
Hi Andrew
I sold lots of those pipes, Great pipes, and were made for f3A Pattern ships, they are heavy for CL ships, but will work.
« Reply #5 on: August 26, 2013, 08:38:50 AM »
Thanks Randy,
Good job I build light these days! Well looks as if I had some luck for once.
Thanks ,
Andrew.
BMFA Number 64862
« Reply #6 on: August 26, 2013, 10:40:31 AM »
Hi Andrew
YOu can put a wooden dowel into the front of the pipe , gently untill it hits the first reflective surface, mark how far in it goes, then put along the outside of the pipe to mark where the first reflective surface is , so you will know where to tune from
