  • July 07, 2025, 04:50:12 PM
Author Topic: Boca Bearing Sale  (Read 1758 times)
Boca Bearing Sale
« on: November 23, 2019, 07:26:29 AM »
blank
« Last Edit: August 28, 2021, 06:29:54 PM by Motorman »
Online Gerald Arana
Re: Boca Bearing Sale
« Reply #1 on: November 23, 2019, 08:55:57 AM »
It never fails, I just bought bearings a couple weeks ago at full price.... :-\
Jerry
Offline mike londke
« Reply #2 on: November 25, 2019, 06:23:34 PM »
Anyone know the part numbers for the bearings on a Thunder Tiger .36? I have a swap meet rescue that needs new ones. Thx
« Reply #3 on: November 25, 2019, 07:18:22 PM »
Mike,
These guys cater to model engine folks. Their website will lead you to a choice of part numbers (and prices) if you know what make, model and size engine you have. And if you aren't sure, then just call them. They have someone to help you get what you need.
I would stay away from hybrid/ceramic bearings. No need for them on a sport motor. Save yourself a buck--and maybe your engine.
If you are not familiar with changing bearings on a model engine, there are some decent videos out there. The process should involve controlled heating of the case. If someone is telling you that you need pliers, hammer, etc. then look for a different source of info. Some engines are built with a tighter bore that makes it more difficult. But there is no point in taking out old, rusty, Brinelled (from crashing into the ground) bearings--and putting in new ones that are damaged during installation.
The Divot
ref:
https://www.bocabearings.com/products/enk-077mx-14369?make=THUNDER TIGER ENGINES&model=PRO 36H
« Reply #4 on: November 25, 2019, 09:44:06 PM »
   When I worked as a maintenance technician at a large commercial printing plant, I worked with and had to identify bearings that ran the range of what some call "sewing machine bearings" to the main blanket cylinder bearings on some presses that are about 10 inches in outside diameter and weigh about 25 pounds! We had a book in the maintenance department from Nachi Bearing, and it listed every bearing you could think of by dimension, style and number. I have  never looked for it on line but I bet they have that listed somewhere. The standard numbering system will be helpful in finding out what mystery bearings are. If we would have had more than one of those books, one might have come home with me!
Offline mike londke
« Reply #5 on: November 25, 2019, 10:12:07 PM »
Mike,
The Divot
ref:
Thank you Dave.
« Reply #6 on: November 25, 2019, 10:43:11 PM »
Mike,
What I'm not sure of is if TT had different models of 36's that used different size bearings. The Motorman makes a good point: if you have to take out the bearings anyway, then measuring them with a micrometer (or accurate caliper) will prevent you from buying something that won't actually fit. You generally don't need to measure to tenths of thousandths. Bearings come in English and Metric series, with well established sizes. (The leadtime for truly custom bearings can be 3 to 5 years, and the cost will make your eyes fall out of your head....And to get those, you don't take to a distributor, you go beg each of the manufacturers until someone puts you on their production schedule. The long lead item is grinding the rings, generally. Unless you need a seal. That can be slow, too.)  The engine manufacturer takes care of the fits with the sizes machined into the case and on the crank.
So the question is whether your bearings really need removal and replacement. If they are rusted, then even when cleaned their life may be fairly short and they will be noisy. However, if the engine was put away gunked up with castor you are in luck. Cook away in your crockpot with antifreeze for a day or two. Flush with brake cleaner. Spin the shaft (piston, liner, rod removed) and listen. If not noisy or does not feel gritty, I'd oil them up and leave them in. I've done this many times with engines that were just not worth putting a new set of bearings in. And some of them have run a long time after that.
The only engines I have had to watch the bearings really carefully on were racing engines, and of those, really only the F2C diesels. They just pound the daylights out of the main bearings--which tended to be undersize to achieve absolute minimum weight and case size.
The Divot
« Reply #7 on: November 25, 2019, 10:49:57 PM »
[quote author=Dave Hull link=topic=55139.msg568863#msg568863 date=1574734702
[/quote]
   Probably right in most cases. In my case, I might be very tempted to replace my RO-Jett 61 rear bearing with a full ceramic, because they are marginal (small and light to save weight) and all of my engines have wound up with chipped ball bearings, which also scored the cylinder on the way out. My first engine has been retrofitted with a larger bearing, but I have had one failure on each of the stock versions. That's *a lot* of flights, but ceramic is much, much harder (watch what happens when they try to crush them on the Hydraulic Press Channel (my favorite)) and much less prone to chipping. They are also pretty well immune to rust or other chemical-based corrosion. They are also astronomically more expensive.
« Reply #8 on: November 26, 2019, 12:08:17 AM »
Ceramics are interesting. Here are a few thoughts.
If you have very high cyclic accelerations and the ball mass is a significant percentage of your total inertia, then there is something there to be had in terms of performance improvement. But we have little need to optimize that, considering where we are operating our engines.
I would use slightly different terminology about bearing failures. From long use, there will be millions of stress cycles and the metal will fatigue. The balls actually have higher contact stresses than the races due to the difference in the radius of curvature of the ball as compared to the race groove. So the balls will generally fatigue first in an all-metal bearing. This results in subsurface damage, and "spalling" which I suppose looks like a chip. Some people will look at a bearing and say the ball is “flaking.” To reduce these failures, you need to reduce either the stress levels, or the number of cycles. Since we run the the engine at the speed we need to run, it just means that you have to replace the bearings more often. As we did on the F2C engines. As you point out, replacing them right after they spall is too late—it generally trashes the inside of the engine. If you skid a ball on one of the pieces that comes off another ball, then things can go bad quickly.
If you are having issues with bearing loads and life, be sure you are getting races made from 52100 steel. (High carbon chrome steel.) Definitely do not get stainless, like 440C which has a lower allowable stress value. While the greater immunity to rusting sounds attractive, proper maintenance will prevent rusting and not leave you with even more life problems.
Before we all rush out to buy hybrids (ceramic balls in steel races), know that when a ceramic bearing lets go, it is at least as catastrophic. I recall sitting in the pit area of the speed circle at the Nats and watching Joey disassemble an OS 65 engine. When he got the backplate off, he poured out a handful of sand. That was all that was left of the balls. It had sandblasted the insides of the engine.
Because silicon nitride balls have a higher elastic modulus (ie. they are stiffer than steel) the ball will not deform as much as a steel one would at the point of contact therefore not distributing the load over a greater area, and the race actually sees higher stresses. There is a cross-over point somewhere that means that your failure mode changes (now races, not balls) and life is not improved further.
Sometimes the engine designer tries to make the engine more compact. And picks a bearing with a small cross section. Which therefore has smaller balls. Which go thru more rotations per crank revolution. Which cuts into the operating hours per million fatigue cycles.
And, as usual, engineering is a compromise. While the ceramic balls have a higher allowable dynamic stress level, they do not like impact loads. For Joe Bellcranks like me, if I hit the ground, I would assume that a hybrid bearing is gone unless I was flying over grass. Soft grass.
The Divot
« Reply #9 on: November 26, 2019, 12:39:58 PM »
In our use the only bearing failures I have seen has been caused by overheating.
   I see rust/chemical corrosion all the time, on other people's engines. The load on the RO-Jett rear is the only one I have seen where the load is such that it chips bits out of the bearing.
   Besides those, I have *very rarely* seen any bearing of any grade or type wear out in a stunt plane, it seems to always be due to avoidable causes.
« Reply #10 on: November 26, 2019, 01:09:20 PM »
There are multiple effects on bearings from heat, and all play a part:
1. Higher temps reduce the strength of the materials.  No real effect on silicon nitride, and small effects on the steels at our temps.
2. The change in bearing preload due to bulk temperature changes and gradients. Potentially a big effect on our engines.
3. The lubrication changes with temperature and operating state.
There are probably others, as well.
It is hard to know the separate temps of each of the components, so it's hard to know exactly how your fits are changing. The easy thing to do is to run the engine on a stand as hard as you expect it to run, then stop it and immediately check endplay again. Under no circumstances should you be able to "feel the balls." Don't know how to say it better than that. (Well, I do, but as I have been "counseled" by my peers, Stunt Hanger is not the appropriate forum for technical matters. Flat earth society, you know?) You of course could fill in some of the temps by external measurement (infrared thermometer) of the case. The case spacing will grow in length more per degree than the crank due to the difference in materials. You might get an idea of the crank bulk temp by just looking at the end of it. Most of the other effects should actually reduce bearing preload during operation, although the contact angle will also affected by the axial thrust to a small extent. All model engines I know of have DB preload geometry.
Bearings self-heat as they run due to friction. More so when run at higher surface velocities. Smaller balls equates to higher surface velocities. A primary function of lubrication is to cool the bearings. Easy to see in the main, less so in the front bearing. But the heat has to migrate further to get to the front, so it’s not as bad as you might expect. And with a front rotor engine, you are dumping coolant thru the crank on every revolution.
I will point out that some engines I have had were more sensitive to bearing internal clearances. In my case, on Nelson .15s, they wanted a bit more clearance than the usual C3 fit coming from Boca. I talked to Henry about this and he agreed, saying that he had success using parts that were a bit more controlled than the C3 spec required. He stated a preference for a specific European supplier that had just what he needed. Unfortunately, he did not have any (many?) left.
You can get an idea of how hot an engine maker thinks his engines will be run by how much of a shrink fit he uses. You don't want the fit between the outer race of the main bearing and the case to become loose at max operating temperature or you will pound the bearing and fret the case. Think black junk coming out the exhaust. I would think this is less of a concern on the front bearing, and yet, many times the front is harder to remove. Perhaps in part because the main often comes out with the crank and you need a tool to simulate the same “ease” when doing the front. Perhaps because the clearance from temp soaking the smaller bearing is less.
When guys go to a catalog to buy bearings, there are often logical questions. "Should I get seals, not shields?"  "I can't see how the front bearing gets enough lubrication. If I get double seals and a grease packed bearing will that be better?" And so on. Interestingly, in many cases you can get a variety of things to work, and seem to work well enough for that engine and their duty cycle to get acceptable life expectancy, that they conclude it is preferred. In fact, perfect. Well, it may be good enough, and still not be perfect. For example, grease packed bearings self-heat more. You are plowing the grease. Work is being done. There is no heat transfer due to flow-thru of lubricant. And bearings are often notoriously over-packed, not grease-plated. My preference is for a shingle shield on the front bearing (outside) and no other shields or seals. If the engine has a close fit between the shaft and the case between the bearings, the total leakage is controlled and limited. Check to be sure there is acceptable end play. And go have fun. I’ll say what every other Joe Bellcrank says---“Well, it’s working for me!”
I suspect that some of the control line speed guys are very knowledgeable about bearing selection and setup for model engines. We could probably learn from them.
Again, just a few more thoughts, for what they are worth. Forgive me for stating the obvious as I rambled.
The Divot
Online Bill Hummel
« Reply #11 on: November 26, 2019, 01:23:33 PM »
The Thunder Tiger 36 did indeed use two different size front bearings. After much frustration, Randy Smith shared the info, and supplied the correct size.
ama 72090
« Reply #12 on: November 26, 2019, 03:29:51 PM »
Lauri,
Why would you mix ball materials in a single bearing?
Offline mike londke
« Reply #13 on: November 26, 2019, 10:20:58 PM »
Mike,
The Divot
It was a swap meet RC motor I got for $5. It was gunked up a little but when I got it cleaned up the bearings sounded like gravel. Opened it up and they are full of rust. It has really good compression so I think it's worth saving. Thx for the info.
« Reply #14 on: November 26, 2019, 11:34:21 PM »
I have the  bearings for the  Thunder Tiger 36 in stock, and  YES both  front sizes
Offline Reptoid
« Reply #15 on: November 27, 2019, 05:41:48 PM »
     Probably 90% or more bearing failures in sport/stunt engines come from poor maintenance or poor assembly. Rust and/or gummed up oil residue will kill a bearing quickly if run. Either will cause the balls to skid and flat spot. This may not cause a catastrophic failure immediately but will rob power and destroy the bearing over time.
       Assembly errors happen regularly due to a lack of understanding of correct technique, lack of proper tools (or misuse of proper ones). In 90+% of model engines end thrust is absorbed solely by the front bearing, i.e. propeller thrust and crash impact. That is by design as the rear bearing is a shrink fit (case must be heated prior to removing/installing bearings)in the crankcase with a limited depth and is a slip or net fit with the crank journal and the crankshaft fore and aft location is determined by the front bearing being captured between the crank bearing face and the prop driver. When assembled there should be 0 pre-load on either bearing meaning if you grab the propeller in one hand and the case in the other you should be able to feel the very slight fore and aft play in the front bearing at room temperature. If there is pre-load on the bearings it will cause loss of power from drag, more heat in the bearings, and eventually bearing failure. When assembled clean and dry (no oil) the crank should rotate to counter weight down from any position by gravity alone.
    There are exceptions in some very high performance engines (F2D, F2C, F2A, etc) that are "integral bearing on shaft" meaning the rear bearing inner race is cut into the crank itself and the bearing is assembled with appropriate balls and a synthetic cage inserted and a couple with a pressed on rear bearing. While assembly disassembly is altered they are still set up with 0 pre-load at room temp.
    If you crash (even on grass), the front bearing will likely be damaged from impact. If you don't run any dirt through the engine the rear bearing should be fine as the front takes all the force. Metal cage rear bearings are probably fine in a lower RPM environment (under 14,000). For High RPM engines like F2D (30,000+) or F2A (40,000+) or any High Value engine; plastic, phenolic, peek, or teflon retainers are safer. Bearings with C-3 clearance are fine for most applications but many high RPM engine manufacturers/tuners speck C-4 for the rear bearing.
     When installing/removing bearings heat the case evenly and hot enough so bearings drop or slip in. If you beat on them, especially ceramics, you will damage them. Ceramics are really only favorable cost/performance wise at extremely high RPM, extreme weight concerns, or extreme heat low lube conditions (not likely in a model engine)
« Last Edit: November 27, 2019, 10:39:23 PM by Reptoid »
       Don
       AMA # 3882
