Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 21, 2025, 07:51:20 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
to fill or not to fill
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: to fill or not to fill (Read 765 times)
roger
Trade Count:
0
Captain
on:
March 09, 2008, 07:40:06 AM »
this is my 1st twin engine job the question is what engine do i want to quit first, the in board or out board. and why? and any other input would be helpful too.
roger
Logged
Alan Hahn
Guest
Trade Count:
0
Re: to fill or not to fill
Reply #1 on:
March 09, 2008, 10:32:44 AM »
Well I would guess you want the outboard to quit first since if the inboard is running by itself, it will yaw the plane outward. The opposite (outboard running, inboard off) would yaw the plane inward---not a comfortable position to be in!
Logged
Mike Spiess
bikemike
Trade Count:
0
Commander
AMA #4060
Reply #2 on:
March 10, 2008, 01:02:07 PM »
With my experience with twins is that if the plane is set up to fly stunt well then as long as you fly level it doesn't matter. Just don't try any maneuvers
They will have less line tension with outboard motor but it never seemed that bad.
Logged
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
