  • June 19, 2025, 02:13:15 PM
Author Topic: Looking for Tank for ARF Streak  (Read 5940 times)
« on: March 05, 2006, 07:24:26 PM »
Can some suggest a 3 oz clunk tank that might fit behind the engine on a ARF Flite Streak. We have one now on the inboard side and it is hard to keep running before launch.
Re: Looking for Tank for ARF Streak
« Reply #1 on: March 05, 2006, 09:17:38 PM »
Hi Paul,
Dan Rutherford (dirty dan) has done a lot of work with inboard tanks of the ARF Flite Streak.  If he doesn't see this, PM him!
Offline dirty dan
« Reply #2 on: March 06, 2006, 02:28:49 PM »
I think I've seen this movie at least once already, but my suggestion for a tank which works every time, and can be used completely stock, is the Hayes 3-ounce Arcey clunker tank.
If you prefer having it mounted behind the engine, this piece may have to be moved forward. Or the leading edge of the wing can be relieved for clearance.
The best option is mounting the Hayes tank on the left of the fuselage.
I have no idea as to what current problems might be. The only functional difference between mounting the tank left or right of the fuselage is that you will have to raise the revs at launch, probably by 800 to  1,000 rpm.
More information here: http://stunthanger.com/smf/index.php?topic=121.0
Dan
Dan Rutherford
