  • July 19, 2025, 03:16:21 PM
Author Topic: Black Oil?  (Read 1536 times)
Offline Joe Messinger
Black Oil?
« on: July 04, 2008, 02:52:38 PM »
Hello,
Recently, I mounted a 40+ year old Fox .35 on a modified Twister that I've had hanging in the shop.  I just wanted to try it out.  I haven't used the Fox in many years.  So many years that I can't really remember the history of the thing.  I know that I used it, briefly, on a Sterling Super Ringmaster back in the 1960's. Beyond that, I'm not sure where I got it, if it was used much or at all before I got it and so on.  The engine turns freely, has good compression and starts easily.
The few flights I made with the Fox/Twister combination weren't too bad after I got the mixture about right but at the end of each flight, the underside of the wings were covered with a black, oily exhaust residue.  Does this indicate the motor not being fully broken in?  Is the black residue caused by internal engine metal (aluminum?) mixing with fuel (wear)?  Is this common for the old Fox engines?
I've seen this black oil before on other engines and have heard various theories regarding the cause but am not sure what the answer is.  Perhaps someone here will know?
I'm using Fox 29% all castor/ 5% nitro fuel for this engine. Four stroke needle setting at take off and during level flight.  Two stroke kicks in when the plane's nose points up.
Joe
Joe Messinger
Offline Jim Thomerson
Re: Black Oil?
« Reply #1 on: July 04, 2008, 03:21:43 PM »
Something is rubbing which should not be. I would not run the engine or fly anymore until I figured out what and fixed it.  Maybe the conrod is rubbing on the back plate, for example.  Anywhere you can find black on the engine, or where it contacts the airplane, tells you something is loose and vibrating, or rubbing.  The oil on your plane should show no color: well, maybe a little pink with pink fuel,
Offline tom hampshire
Re: Black Oil?
« Reply #2 on: July 04, 2008, 05:30:51 PM »
Hi Joe - The black is very serious, as it consists of aluminum chips floating in the oil.  Wipe the oil off the wing,  remove the muffler and run it on the ground for a bit.  If the oil comes up clear, the problem was loose muffler bolts.  If not, then pull the engine and remove the backplate.  The rod can walk backward off the crankpin and scuff the backplate.  If it does this, there will be a wierd triangle shape, resembling the rotor of a Wankel engine, cut into the backplate.  The fix is to either install an anodized backplate, or take a facing cut on the old backplate to true the surface, and install a tinplate cover with JB weld.  Either method will give a hard surface for the rod to bear on, and stop the scuffing.  While its apart, rock the shaft over BDC to see if there is excessive rod wear.  If so, replace the rod.  If the play persists, look at the pin bosses in the piston to see how worn they are.  Next rock the prop tips toward and away from the head, and estimate the crankshaft play.  Any more than 1/16 is suspect, over 3/32 means the main bushing is shot, and its time for a new case.  Let us know.  Tom H.
Re: Black Oil?
« Reply #3 on: July 04, 2008, 07:31:29 PM »
Every Fox 35 I have seen that has not been run for a period of ten years or more, will have the rod frozen to the wristpin. If you take the backplate off and cannot slide the rod back and forth on the wristpin, it will wear on the backplate and cause the black oil. The only way to free it up is with heat and solvent.
Re: Black Oil?
« Reply #4 on: July 05, 2008, 07:03:55 AM »
I thought that was normal. All mine do that all the time. ~^ I then sell these gems on ebay.Want to buy some good motors cheap VD~.   Just funning ja
EddyR
Re: Black Oil?
« Reply #5 on: July 05, 2008, 10:10:35 AM »
Hello,
As Tom Hampshire suggested, I removed the muffler from the Fox and ran about 2 oz. of fuel through it. With the muffler off the engine, the exhaust residue is clear.  No more black oil.  The muffler is a strap on variety that doesn't fit especially well and, apparently, vibrated enough to generate lots of aluminum chips that mixed in with the exhaust.
Thanks, Tom and to all who responded to my question.
Joe
Joe Messinger
