The title says it all........any help will be appreciated. I know a couple of techniques but believe that there must be a better way.
I assume you burp it first, with the airplane held inverted, with a helper (or not if you are super-cool like David and I). With a PA, unless you have been very careful since the last flying sessions, you more-or-less can't started it on it's feet. Same with the OS. You have a chance with a RO-Jett, but I still never do it.
Once it is burped, if the engine has cooled from the last run, fill tank, pull through with finger over the intake 3-4 times (choking) , then remove finger and flip through forwards immediately, about 5-6 times (aerate). Hold on to prop to attach the battery. Once the batter is connected and the helper is holding, bump the engine up against compression backwards, should start right off. Try a few more times. If you get nothing, no pops, then hold prop, remove battery, repeat choke procedure, repeat aeration procedure, hold prop, attach battery, back-bump.
If it is still hot, fill tank, pull through compression once or twice, aerate, hold prop, attach battery, bump backwards. My PA61 and most PAs need at most one choke when hot, and 3-4 when cold.
Note that back-bumping is not flipping it backwards through compression, you never flip it through compression in either direction, unless you have some spare fingers. Just turn it CCW until it starts to come up on compression, then fling it backwards up against compression in the CW direction. Don't use a chicken stick or anything like that. If you are doing it correctly, your fingers are not on the prop or spinner when it pops.
You have to experiment to know how much to choke under different conditions. Usually, you can tell by the sound it makes when you are aerating it. It should sound slightly juicy, more than it you were going to flip it through forward. Any excess will be blown out. It will take much more choking when the engine is cold than when it is hot. If the engine is in an intermediate state, it may be very difficult to start because you have to choke it, and the cold fuel will get on the underside of the piston and shrink it, and leave the sleeve hot, so the compression will sort of go away. If this happens, aerate many times until you feel the compression start to come back.
NEVER attach the battery without holding the prop, and NEVER flip it with fuel in it unless someone it holding it. The engine can start without the battery pretty easily, once you get the perfect mixture. It can also start spontaneously when you attach the battery. These are extremely powerful engines with very strong razor-sharp propellors, and have such good piston fits that they can start in conditions when you do not expect, once it is choked and aerated properly.
