  • July 11, 2025, 10:20:41 PM
Author Topic: Best sealant for case to NVA?  (Read 4971 times)
Online Dennis Toth
« on: December 24, 2017, 03:45:40 PM »
Guys,
What is a good sealant for the NVA to case area? I have had some issues with the seal where the NVA goes through the case/venture on my Fox 35. I am using a Randy PA Fox NVA. This is an excellent needle valve with good needle seal and fine adjustability. On the needle side there is a boss that has two flats cut in to allow a wench to hold it for tightening. The area of the boss by cuts is very small. If not sealed as the case heats any amount of leakage changes and the setting can go erratic. What sealants work for this?
Best,    DennisT
Offline kenneth cook
Re: Best sealant for case to NVA?
« Reply #1 on: December 24, 2017, 05:21:47 PM »
                   Dennis, a fellow member of our club was using Permatex Ultra blue. I have used Ultra black only to find it breaks down in alcohol but I believe Ultra copper works well too. It's difficult to keep neat so I wouldn't recommend using the tube as a applicator. I prefer fiber washers myself such as the ones found on Perfect bellcranks. Another option for you to try is a small O-ring. These can be cut from silicon fuel tubing by pushing a piece of tubing on a dowel. Chuck it up in a drill press and carefully hold a X-acto to the tubing squarely. This can yield different thickness and accurate cuts.
Offline Manuel Cortes
« Reply #2 on: December 25, 2017, 12:08:49 AM »
Hi all.
Tom Dixon told me about 20 years ago (throgh letter, as today) the recommendation to use a drop of epoxy in the área between the case and NVA in order to seal the joint in Merco 61. I´ve used that without a fail. Removing it is simple heating a Little.
Hope it helps.
Regards.
Manuel.
Online Dennis Toth
« Reply #3 on: December 25, 2017, 06:56:31 AM »
Guys,
Good information, Ken I like the tubing cutting idea, Mannuel I never thought of the expoy but you have a good point. I had tried the Permatex Gasket Sealant, this comes in 5g foil packets at Auto Zone. I thought this would be great since I only use a drop on each side of the NVA and don't need a 6oz tube that goes bad in six months (usually the cap cracks and that's what lets air in and it cures the whole tube). The Permatex said it was oil & gas resistant (it didn't say nitro/menthol).
When you mentioned that Ultra Black broke down I got up from the couch and did a little test. Fuel dissolves it. I think this caused my problem. I think I am going to make a gasket from some 0.005" shim stock that I will solder to the flat side of the spraybar, this should give more area to seal against the case. Then might see if I can find the Ultra Blue or Copper sealant. If I can't find it I will go the expoy route. Thanks for the information.
Merry Christmas/Happy Holidays,      DennisT
« Reply #4 on: December 25, 2017, 07:12:53 AM »
Regular old dow Silicone II solicone sealant appears to work fine, although clear is a problem because you can never see where it goes for sure. I use Ultra Copper since I have it anyway, and, you can tell when you get it in the wrong place, which can be disastrous.
     BTW the value of sealing the venturi to the case for the OS/Fox/McCoy "through the middle" spraybar is minimal. Even if it leaks, it has no real effect unless the leak is intermittent. It can have a drastic effect on the ST/PA/RO-Jett style sprinkler-type venturi, it is exactly identical to having a leak in the fuel line. You just have to be very careful to only get it where it needs to go, and not into the manifold or spraybar itself.
 Interestingly. most of the difference is detectable on the ground when needling it, or just sitting there while you are walking out to the handle - it will just surge up and down. If you aren't changing something, it should just sit there at a constant RPM, or *slowly* speed up or slowing down. If not, something is leaking somewhere.
« Reply #5 on: December 25, 2017, 10:53:42 AM »
   Something you can do at the field is use thick C/A glue and C/A kicker. Just dab it around the suspected area, hit with kicker, and go test fly. Fuel won't get to it and to remove it, just pick at it with a small screw driver. You can seal back plates the same way if you suspect  an air leak. If it solves the problem, then youknow where to look the next time you have the engine out of the model.
   MERRY CHRISTMAS!!!
Online Dennis Toth
« Reply #6 on: December 25, 2017, 01:48:38 PM »
The issue I have been fighting is very close to what Brett described. The engine (Fox 35) will start set in a good 4 cycle then as it continues to run starts going leaner. If you richen it is will go back to the deep 4 cycle, if you try to fly it will either be sloppy rich or if launched a bit closer will fly great for a few minute then lean out.
I have changed tanks three times, change the engine out, changed all the tubing. Only thing that is common that was not changed (in both engines) was the PA NVA. Looking at the NVA, needle side where the wrench flats are cut, there is no real shoulder to seal along the case boss. The sealant (Permatex gasket sealant) I used seems to be dissolvable by fuel (finally tested that today). I think some got washed out on the bottom edge (I had the venture fill during fueling). I will get the Ultra Blue or Copper and try again.
Best,    DennisT
Offline Ara Dedekian
  • Ara Dedekian
« Reply #7 on: December 25, 2017, 03:53:52 PM »
       Teflon tape twisted into a strand and wrapped around the spray bar where it contacts the case on both the nipple and nut side.
       Ara
Online Dennis Toth
« Reply #8 on: December 25, 2017, 05:40:03 PM »
Ara,
Great idea with the Teflon tape. My problem is that with the PA NVA there is really no area to seal against the case boss where the flats are cut. If I make the shim washer and solder it to the NVA then the Teflon tape will work.
Best,    DennisT
Offline bob whitney
« Reply #9 on: December 25, 2017, 07:12:09 PM »
Dennis, I make both fiber and aluminum washers for the spraybar
rad racer
Offline Lauri Malila
« Reply #10 on: December 25, 2017, 11:49:39 PM »
Hi.
Sorry but I don't understand what kind off stuff you are talking about if there is an issue with sealant dissolving in fuel. That kind of things should be avoided.
Also, the pressure difference is not so massive, it's usually enough just to smear some sealant on outside of engine/valve connection, just to make a kind of a fillet. I like the red Plastik Padding "Gasket" silicone sealant. Any similar silicone will work but red is nice as you can see where it is. If you don't see, get a magnifying glass.
Also, it's important to apply the sealant to clean and dry surfaces.
Other reason why you don't want sealant inside the joint is that it's very slippery, and you need to tighten the valve much tighter to avoid rotating. Some engines, like Retro, are sensitive to this because over-tightening will deform the venturi hole and engine front end, and screw up the bearing play. In this case also a snug fitting aluminium venturi helps. L
Offline Phil Krankowski
« Reply #11 on: December 26, 2017, 08:51:09 AM »
The auto parts store will have aluminum safe anaerobic flange sealant.  It will cure only where it is in a joint and wipe or wash away everywhere else.  It will disassemble relatively easily, with the dried product wiping away as a brittle film.
The threads of the nva can be sealed with fuel line.  The fuel line also stops vibration from moving the nva.
Phil
« Reply #12 on: December 27, 2017, 06:40:02 PM »
      That's overheating or worn out, not a leak. The surges from leaks take place over the period of a few seconds, up and down. What is happening here is something heating up over the period of 10+ seconds, if I understand correctly. When you launch it, it cools back down, making it go richer (usually).
    My first suggestion is to put in more oil, to cool off the engine, or to alter the cowl (full-fuselage) or a cylinder baffle (profile).
      It would be very unusual for a case/spraybar leak on this type of spraybar to be a problem.
« Reply #13 on: December 28, 2017, 11:03:13 AM »
Guys,
Best,    DennisT
Hi Dennis
I doubt  that is the problem, I have sold , and used  100s of these  in FOX 35s  and  have  never  seen  what you are saying  caused by the  NVA,  most likely it is another  problem, like what Brett  stated,  or a  damaged case at the  NVA hole,
If you do have a nad surface on the case  where  the  NVA goes thru, and  you need to seal it, you can use 1 or 2 layers of  metal duct tape, or wrap the end with telflon tape
Online Dennis Toth
« Reply #14 on: December 28, 2017, 12:52:02 PM »
OK, changed the NVA to a ST 51 NVA with an added washer to center the hole, sealed with black silicon. NVA was positioned with the hole facing rearward same as with the other NVA. Beside the NVA itself the other change was the sealant. All the Fox's I seen have a very small boss on the case to seal against and it is not always perfect and in my option needs sealant. I had used a material from Permatex called gasket sealant. This material never hardens, later I did a test that showed fuel could easily wash it away. With the black silicon it cures and although it is not nitro proof it doesn't dissolve the way the gasket sealant did. I believe this is the real culprit, not the PA NVA but I already changed it so I decided to fly it to see if anything would change.
I went to the field today and flew. This is my El Diablo, open front upright engine, uniflow tank, muffler pressure, 7% N;28% oil (76C/25S), 9x6 Top Flite spoon blade prop. Engine started 1st flip, initial setting was very rich, l leaned to 9500 rpm, kind of just breaking 4/2 for launch. In the air went to a rich 2/4, lap time was 5.0 (60' C to C). The run was totally solid, not a 4-2-4, more of a 2/4 -2- 2/4 but the motor never ran away was almost like flying electric. I got though the whole OTS pattern, totally solid. Upright/inverted laps the same. For me the big test was the 5 inside and 5 outside loops. This is were it would go off before around the 4th loop. Not today just solid. At the end of the flight by the time I walked the ship back to the pit you could hold the cylinder, it was warm but not real hot. Oil was nice clean castor color, no signs of excess heat.
Now that it seems to be flyable I would like to try and get the lap time down to around 4.9 sec. To get a few more rpm to make up for the wider ST NVA I will try to bump the nitro to 10% or play with the prop, try a 10x6 or up the pitch up the 9" dia to 6 1/2 pitch. Last will go back to the PA NVA with the silicon sealer.
Best,    DennisT
« Last Edit: December 28, 2017, 02:46:34 PM by Dennis Toth »
« Reply #15 on: December 28, 2017, 03:39:59 PM »
another  thing you changed  was the  suction, you increased the suction dramatically  when  you put a much larger  diameter spraybar, The weather is  NOW  colder  so you might not have noticed a huge power decrease, but  higher nitro will help for that
Caution though  increasing the  suction can  mask engine problems like worn out parts. for one , it will mask other problems too, at the cost of power.  No matter  what  NVA  you use, the  two  techniques  I gave you about sealing will work
Offline Allan Perret
  • Proverbs
« Reply #16 on: January 07, 2018, 03:48:39 PM »
I use Red Hi-Temp Permatex silicone for headers and mufflers.  So I use that also to seal spray bars.  I figured out the cap cracking issue, solved it by squeezing out some sealant, screw cap on lightly, let the sealant harden an form complete seal to not let air get to rest of tube.
Allan Perret
AMA 302406
Slidell, Louisiana
Online Dennis Toth
« Reply #17 on: January 11, 2018, 05:38:34 PM »
I got some Permatex Ultra Black Gasket Maker silicone, it comes in a small tube 1oz. I used this on my El D Fox 35 NVA at the case interface. It has worked great. I did a test of the material that was cured on the small business card that I used to wipe the excess off on. I poured raw fuel on it and let is sit for a day. The material was not affected at all. Seems like a good material to use for sealing the NVA areas.
Best,    DennisT
Offline Phil Bare
« Reply #18 on: January 12, 2018, 01:49:27 PM »
The needle is set to the total airflow through the venture. A air leak around the spray bar makes no difference as long as it is consistent. The aluminum crank case will expand more than the steel or brass spray bar. The spray bar will tighten up.
Phil Bare H^^
Online Dennis Toth
« Reply #19 on: January 12, 2018, 07:54:14 PM »
The problem is that if there is a leak (from a rough boss surface, too small a spraybar diameter, small spraybar seat, etc.) as the engine heats and cools during the pattern it can change the air flow into the engine. As the aluminum hole heats up it expands out, not in. If you are pulling a bearing or a tight sleeve you heat the case and it expands and allows the bearing/sleeve to be pulled out.
This sealant eliminates the air leak around the NVA issue.
Best,    DennisT
« Reply #20 on: January 12, 2018, 10:33:56 PM »
Ive seen some tough redish rubbery stuff on a few S/H Engines I have , just ' clicked ' seeing this thread I was going to keep my nose out of ,
probably PLIOBOND , which you cant get in Aus. As a glue any coments I have would be libelous .
As A Gasket Cement , in the time of NOAH , the top British Bike Overhaul outfit used it , guess wot. No Oil Leaks .  %^@ %^@ %^@ %^@
Bit of a swine to remove from casings , but heat proof on a case . Semi Permanent Semi Elastic . So worth a try .
While on the old torrey cannyons , Copper Coat - copper graphite - pressure sealing compount , and copper head gaskets ,
If youve got a leak with that , somethings seriously wrong . Its also Anto Sieze Paste ! , so comes apart easy & clean
if used on all other gaskets . and good for anything ( bolts, nuts , gaskets ) at the Exhaust Ports . For these tooned pipe flange individuals .   H^^
« Reply #21 on: January 13, 2018, 10:46:27 AM »
   Oy gevalt!
https://www.amazon.com/Permatex-81878-Maximum-Temperature-Silicone/dp/B0002UEOPA
   Almost certainly available everywhere in the world. There was an entire article about this in SN Jan/Feb 2015.
Offline bob whitney
« Reply #22 on: January 13, 2018, 04:38:08 PM »
take an old N/V body .put it in the engine worth some fine valve lapping compound and hook up a variable speed drill to the other end .start drill and pull the N/V head against the body and it should face it off .be sure to clean all the compound off.
rad racer
Online Dennis Toth
« Reply #23 on: April 21, 2018, 11:12:24 AM »
OK, I have now come full circle. After getting all the leaks sealed up in the tank, glow plug got the uniflow vent pointing into the airflow on the inside of the fuse with the ST NVA installed in my Fox 35 El D everything worked as it should, but was a little short on power, but the run was solid. Once I got to the point were every worked I wanted to go back to the PA NVA. to get that little extra power back. I added a thin tight fitting washer on the needle side of the spraybar for a solid seal against the case and applied the silicon sealer that worked well with the ST NVA. I can report here that this worked very well the run was solid with the added power of the reduced spraybar area. All sealed perfectly and held steady through the flight, the break was just were I wanted it.
Best,   DennisT
