  • June 26, 2025, 03:55:59 AM
Author Topic: Best plug for ST .46??  (Read 1960 times)
Offline Ty Marcucci
« on: September 04, 2006, 01:15:37 PM »
xxx
« Last Edit: March 20, 2017, 10:41:55 PM by Ty Marcucci »
Ty Marcucci
Re: Best plug for ST .46??
« Reply #1 on: September 04, 2006, 01:18:32 PM »
In the last three days I have gone through five glow plugs on two St .46 engines. This is very unusual.  I use the Fireball long RC plugs, never a problem on OS engines especially the OS .40/46/35 FP or LA engines.  Same on Fox L&J engines.  But five plugs in three days seems very high usage, even for me.  10% nitro, 28% oil, all castor as reccomended by Tom Lay.  One engine on a Cardinal, one in my scratch Cobra. Both planes by the way fly beautifully, right until the engine suddenly stops.
Ideas, answers, comments, questions?? ::) ??? :P :!
Don't have a clue as to what is causing your problem, Ty.  What does the plug look like when you pull it?
I have been using the Thunderbolt, either the  4 cycle plug or the R/C long.  No problems with mine blowing plugs. ???????????????
Bill <><
Bill <><
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: September 04, 2006, 01:24:39 PM »
Something's not right, if the compression is too high it will blow plugs but a few other things can also be the cause.. Tell us what the plug looks like when you remove it. Not running your glow driver too hot are you?
« Reply #3 on: September 04, 2006, 01:32:26 PM »
Hi Bob. No, these are the normal glow drivers most of us use. In fact, one was down.
I think I better contact Tom Lay and ask about the compression ratio on these. Do you guys know if he kicks it up a tad??
having used several of Tom's engines, I can't say that he kicks the compression up enough on a stunt engine to burn out plugs. ?????????
My  T&L ST G51 went two seasons on one plug, and then it was still good.
Never had to change plugs in my 46s either.
Better give ol' Tom a call!  y1
Bill <><
Offline Bob Reeves
« Reply #4 on: September 04, 2006, 01:39:18 PM »
Is the coil deformed? If so it's likly over compression..
Offline Ralph Wenzel (d)
« Reply #5 on: September 04, 2006, 02:18:58 PM »
Just a comment, and I don't really know how or why it might cause this effect, but Tom recommends 22% - 24% all-Castor fuel, I think. At least on his ST V.60s.
Ralph Wenzel
AMA 495785 League City, TX
Eric Viglione
« Reply #6 on: September 04, 2006, 02:27:36 PM »
Ty -
28% sounds like a lot of oil, even if Tom relieves the ring groove for running all castor. I've run nothing but 22% 50/50 in all my ST's for the last several years, hundreds of flights, yet to wear one out. I'd not want to contradict the engine tuners instructions, but I also would be tempted to ask him if running Sig Champion is ok.
If your 46 is a newer model, with muffler lugs, it could very well be the version with the high compression head with the huge squish band.
Throw in a .10 head shim and switch to a K&B 1L (long idle bar) plug. I'd bet your problems vanish.
EricV
Offline Greg L Bahrman
« Reply #7 on: September 04, 2006, 03:59:42 PM »
Tom Lay recommended 22% all caster in the ST 46 he did for me. Never had a problem. It was the one with muffler lugs. I use the K&B long with the idle bar. It just runs and runs etc........... Although if you have bad bearings or a ring gone south, dirty fuel etc.?
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #8 on: September 04, 2006, 10:25:56 PM »
Look for signs of scuffed aluminum parts... backplate, rod and piston being the likely source. Aluminum particles will kill the plug real quick. Not likely on a BB engine, but maybe the shaft end-play isn't right. I've had that situation on early ST's before they put the little spacers in behind the front bearings. Might also be worth taking a look at the mufflers, to make sure they aren't clogged up with carbon.  :X  Steve
Offline Ted Winterman
« Reply #9 on: February 18, 2007, 11:33:43 AM »
        Ty,
   Went through plugs like mad with my ST .46's & .60's. I quit using Armorall and the problem
went away.
       Ted
« Reply #10 on: February 19, 2007, 04:06:04 PM »
Hi Ty,
Strange you are running 28% oil. Did I read that right? Tom told me to use 22% all castor in the ST 46 I got from him ???
Simi Valley, Ca.
