  • June 21, 2025, 11:56:19 AM
Author Topic: Fuel choice for OS Engines  (Read 3517 times)
Offline Mark Misegadis
« on: June 07, 2012, 03:27:12 PM »
Currently my flying partner and I have been flying some Craigslist Specials.  A Sig Twister with a LA46 and a Banshee with a OS 35 FP. We have been running Magnum fuel that is 10% Nitro and 20% lube that is a Synthetic/Caster mix.
I would like to ask for the experience and opinions on these modern engines for fuel. We are at around 6000 feet here in Colorado and considered playing around with some 15% Nitro fuel. We want to take good care of these engines so I thought I would ask if this is too much Nitro?
While I dont have specifics in the lube ratio at the moment I am writing this, is there any concern over the current fuels that are a much higher percentage of Syn to Caster in these particular engines.
Thanks!  Mark
Offline scott matthews
Re: Fuel choice for OS Engines
« Reply #1 on: June 07, 2012, 07:45:44 PM »
I typically use Siq 10% fuel with 18% synthetic blend oil and have great engine runs. Set engine in a rich 2 stroke run .
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: June 07, 2012, 09:56:46 PM »
15% is not too much nitro.  At high altitudes 15% nitro is the preferred amount for most stunt fliers. I would suggest adding 2.6 ounces of castor oil to your Magnum fuel. That would make it approx. 22% lube total.  8)
« Last Edit: June 09, 2012, 01:34:25 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Offline Dennis Moritz
« Reply #3 on: June 08, 2012, 06:02:59 AM »
We use Powermaster 22%(50/50) 5% in everything. Definitely in LA46s and FPs. But we fly at sea level in the frequently humidity laden air of Philly, PA near the Delaware. Upping the nitro for flying at higher elevation makes sense to me. There are issues besides percentages of lube/methanol/nitro. Questions concerning what kind of synthetic lube, also, there's the issue of how the ingredients are measured by volume or weight. Measuring by volume means a greater percentage of lube, which is the way to go. I have heard of folks running Powermaster 18% lube in OS plain bearing engines. Their experience purporting to be positive. Dunno. I wouldn't go that low, no need to risk the longevity of our power plants. I am concerned about the new Powermaster, however, that is colored pink our of the can. The old stuff, mixed up by a family owned business who chose the ingredients of the chemical mix, having given up the business. The chemical manufacturer now mixes the brew. I guess the same chemicals are available, but the color difference makes me question whether a different synthetic lube has been substituted. I will call (sometime) the new mixologists. At the moment, tho, club members find that pink, so far, works as well as clear.
« Reply #4 on: June 08, 2012, 09:17:43 AM »
I've run many FP's and LA's especially the 46.  I pretty much agree with what Dennis M. said about fuel.  However I would simply add that I've used up to 25% nitro here in Tucson (2500 ft 100+ temps with no real problems).  I've also tried low oil content and found that theLA46 runs best on 10-15% nitro and 18% oil (half and half, with Klotz)...notice I said "best".  The plain case bearings wear out with a resultant loss of power and greater fuel usage in about 200 or so flights with the low oil content.  One of my buddies here in Tucson swears by 24% oil content and gets good runs.  Personally I think the 22% half and half using Klotz is probably the best compromise.  I have a couple of LA46's that have always been run with this mix and have over 1000 flights with no real deterioration in run quality.  The Klotz keeps everything nice and clean inside the engine also, which I've found not to be completely true with all synthetics.
Randy Cuberly.
Offline Dick Pacini
« Reply #5 on: June 08, 2012, 10:19:39 AM »
Randy Smith wrote a good piece on fuel.  It's a sticky at the head of this forum.
http://stunthanger.com/smf/index.php?topic=4037.0
AMA 62221
« Reply #6 on: June 09, 2012, 10:42:46 AM »
Thanks everyone for the responses so far.  Great stuff. That Randy Smith article is a wealth of information. I will have to check the fuel jug today to verify exactly what it says on the lube.
Mark
« Reply #7 on: June 09, 2012, 04:29:39 PM »
Also, be aware that OS FP's were made with iron piston/steel sleeve, as well as ABN (Aluminum Brass Nickle) piston/cylinders. General opinion is that they need different oil, but some will also tell you that the iron/steel is ok with all synthetic as long as it isn't coked up with castor oil...in which case you really don't want to upset the apple cart and change to synthetic. A search will turn up a lot of facts and opinions on the subject.  LL~ Steve
« Reply #8 on: June 11, 2012, 11:56:12 AM »
I checked the fuel jug this morning.  All it says is Syn/Caster Blend.  It looks like I'll need to call the manufacturer up to get the ratio.   Mark
« Reply #9 on: June 11, 2012, 03:19:16 PM »
 Just get some SIG castor oil and pour in about 10-12 oz. and don't worry about it any more. Note that a lot of the need for the oil is to supply some non-volatile filler to carry away heat. That's about as important as the lubricating qualities.
Offline nathan Metzner
« Reply #10 on: June 12, 2012, 01:39:50 PM »
I am using brodak's 10% Nitro 11.5% synthetic 11.5%castor in my os max .25 &.15. These are earlier engines so they may like the castor more than the newer ones. I am also using os 8 plugs. Both engines run extremely well. As I remember the .25 turns 14,500 or so with a 9X4 and the .14 does about the same with a 8X4.
Nathan, New guy, Newbie, Youngster, Pleeb, So on and so on
« Reply #11 on: June 13, 2012, 10:21:27 AM »
We generally use Sig Champion 5% nitro most of the year going to 10% nitro in the heat.  It's 1/2 and 1/2 synthetic/castor.  And hot plugs.
This is for all our OS engines except the OLD "S" series (.30S, .35S).  For those we add about 5 oz. of castor to the fuel.
BIG Bear
RNMM/AMM
« Reply #12 on: June 15, 2012, 03:30:05 PM »
Howdy,
I just spoke to Buzz at Magnum Fuels. He was very willing to help me out and answered all of my questions. All his fuels are blended with the ingredients measured by Volume.
The Magnum “10% Sport” that we are running and the “15% Sport” that we are going to try out are a 18% oil pack. The ratio on the oil pack is 13%-Syn and  5%-Caster.
Per the Randy Smith article:  For motors with larger bushings and bushed rods like the OS FP , Magnum GP series, Tower, and  Brodak’s  a 22-25% half-and-half oil mixture works the best.
(We are currently running OS-FPs and OS LAs)
Per Buzz I can add 7 ounces of Caster to the new 5 Quart jug of “15 Sport” and  get an oil percentage of 22% +.  There is a jug of Sig Caster at the hobby shop they are holding for me that I will be picking up to do this.
In the future I can request specific custom blends through my  local hobby shop that Buzz said could be easily mixed with no lead time and sent along with his regular order.  We try to support our hobby store (Pikes Peak RC Hobbies) whenever we can and this will help us do so as he now only stocks Magnum Fuels due to the requests of his larger customer base.
Plans are to get a mix like the one we are doctoring up now as a custom blend from Magnum and a “Fox, McCoy, S MAX” blend made up.  (Fox Mix = 10% Nitro, 50/50 Syn-Castor 26% total)
Thoughts on the mixes before I order them up?
Thank you!
Mark
Online RandySmith
« Reply #13 on: June 15, 2012, 11:05:06 PM »
"Plans are to get a mix like the one we are doctoring up now as a custom blend from Magnum and a “Fox, McCoy, S MAX” blend made up.  (Fox Mix = 10% Nitro, 50/50 Syn-Castor 26% total)
Thank you!
Mark"
Mark
That will work very well  on the motors you listed, unless they are old and very carboned up with burned on  castor, If they are clean then use the fuel you listed.
If they are carboned up and have lots of brown.black burnt on them use all castor 25 to 28%.
