Engine basics => Engine set up tips => Topic started by: Mike Scholtes on July 29, 2016, 12:19:56 PM
Going to order some props from Brian Eather. What would be the best of his 3-blade props for a PA40UL on pipe in an Oriental Plus with 605 area? Brian's current offerings in 11 inch diameter have 5.75 pitch, which seems like a lot for this setup, but I don't have any experience with his props. 12 inch props are available in 3.75 but that seems like a lot of diameter for this setup.
The Best Prop I found is the Bolly 11 x 4 N 3 bld
2nd best Magic 12 x 4 n 3 bladcut to 11
3rd Bill LEE thin 11 x 4 3 blade
Bolly 11.25 x 4 N 2 blade
Any Eather 11 x 4 N 3 blade that is close to the ones above
I know these are somewhat hard to find,, another that works well is the Werwage 10.6 x 4.9 wide U/C 2 blade
Thanks Randy, no better authority than you on this.
