When I bought Danny Dirt's old ST G.51 (in the Mutant Magnum), it had a ST spraybar assembly, no bend on the needle. It had a pinion gear (aluminum!) from some R/C car for a knob. Set screw held it fine, with some locktite.
I thought this was a cool idea, so when I setup my DS .60bb with a Randy Aero NV assembly for the "Lancer", I did the same thing. Out flying one day, the ST NV snapped off at the spraybar. Hmmm. A few weeks later, the Randy NV snapped off at the spraybar.
I'm in a quandry. I know that the imbalance of the bent 'handle' on the NV is what makes them tend to rotate. Plus, the knob (pinion gear) is easier to use, less awkward, therefore less danger of putting your fingers into the prop. But the darned things break off the NV. Anybody got a good solution...a knob that doesn't weigh anything? I expect I'll have to shorten the NV as much as possible. Might also consider a non-needle mixture control valve (pinch fuel line, like the R/C in-flight systems), with a micro screw adjuster vs. servo.
Uhhhh...I use a TF magnetic prop balancer, engines didn't come loose. Also, how to get the broken NV out of the spraybar?
