  • July 15, 2025, 06:27:16 PM
Author Topic: More Nitro = Higher Engine Temp' ?  (Read 1112 times)
Offline Robin_Holden
« on: March 24, 2015, 04:26:57 AM »
Fellas , help me out please .
Does increasing the nitro content in fuel mean the engine runs hotter ?
Testing my TT 36 on the bench yesterday  , she seemed to run hotter using  fuel with 8% Nitro/ 20% lube'.
Normally I use around 5% nitro , along with 20%  lube'.
Much obliged ,
Robin , in the countryside in S.W. France.
Re: More Nitro = Higher Engine Temp' ?
« Reply #1 on: March 24, 2015, 03:22:39 PM »
Much obliged ,
HI Robin
The answer is most always NO, in stunt you do not lean more with more nitro, you normally use the same or richen the mixture, plus you are again , normally using more fuel when you add nitro, this give the same or most times a cooler run.
However "if" you are peaking the engine out, then YES you can run hotter with more nitro.
Remember running hot is normally a function of how lean your running the mixture.
« Reply #2 on: March 25, 2015, 12:59:41 AM »
HI Robin
Thanks randy ,
Much obliged.
Robin.
