I had the same problem on a old motor, I got a tip for alum duct tape. I have used it for head gaskits and back plates. I had a role on my work van that is used for fiber duct, that is a little thicker than steel duct tape. I used two peaces one on top of the other and then stick it too the surface, and then cut it out with a No 11 blade. You can make it any thickness you want, and it comes off ez if you want to try a different thickness. Its fast and it works great.
