  • June 13, 2025, 12:05:42 PM
Author Topic: Back plate gasket made easy.  (Read 5472 times)
Offline Perry Rose
« on: June 23, 2024, 01:19:21 PM »
In particular the O.S. LA engines use a gasket that is .005 thick. So is packing tape. I cleaned the mating surface of the crankcase and stuck a piece of tape on it. Then I cut the center hole with a new Exacto blade and opened the bolt holes with a hot piece of sharpened rod. A little trimming on the outer perimeter and I have a new gasket.
Re: Back plate gasket made easy.
« Reply #1 on: June 23, 2024, 01:45:06 PM »
Dam Perry, great idea!!
Should work for anything but the head gasket.
Best,    DennisT
« Reply #2 on: June 23, 2024, 03:53:22 PM »
Hope the heat of the engine doesn't shrink it.
Offline Gerald Arana
« Reply #3 on: June 23, 2024, 07:04:35 PM »
I use an old paper bag.............and trim it the way you do. Works great.
Cheers, Jerry
« Reply #4 on: June 24, 2024, 10:49:43 AM »
I do the same thing with aluminum duct tape.   Works fine for head gaskets and header pipes too.  Just re-tighten a bit after the first run while still warm to squeeze the tape gum down a bit more.
