  • July 05, 2025, 11:20:39 PM
Author Topic: Aviastar 61-- anyone have any experience with this engine ??  (Read 4935 times)
Online TroyMartin
« on: March 08, 2025, 02:59:39 PM »
Anyone have any experience with this engine ???
« Last Edit: March 08, 2025, 11:03:03 PM by TroyMartin »
Re: Aviastar 61-- anyone have any experience with this engine ??
« Reply #1 on: March 08, 2025, 11:07:36 PM »
  Were these distributed through Brodak? That is ringing a bell a bit. I think they came out of England?? I do not think they saw wide spread use. One thing about any engine you may be considering, just look through contest results and see if you can find the engine in question. If any engine showed any promise or really delivered on performance, you can bet that some one would be using them. Search through the forum here, and if anyone was using them in the last 20 years, you should find mention of it!
« Reply #2 on: March 09, 2025, 12:37:41 AM »
While I don't have any personal knowledge of users, I would send a PM to Robert Zambelli and see if he has any info, as he did some R&D work for Brodak...oooh, maybe 25 years ago now.
Generally speaking, the Chinese made (pretty sure it is one) engines aren't quite as much high rpm screamers as even OS engines, but if you run 4" > 5" pitch in a 2-2-2 type run, they'll be useful enough for most. So, the question is, how serious are you about your stunt flying, and are you a 4-2-4 devotee? Remember not to trust the nominal pitch markings on most propellers. A 4" pitch APC might work quite well. IIRC they make a 13-4W that could be suitable.  D>K Steve
« Reply #3 on: March 09, 2025, 01:21:01 AM »
I've had one apart. Not sure what info you are looking for?
Offline Allen Eshleman
« Reply #4 on: March 09, 2025, 11:58:48 AM »
Has anyone out there had good success with these engines?
« Reply #5 on: March 21, 2025, 08:31:20 PM »
The one in the picture had a spun rod bearing. It also had a cracked rod. No way to tell which happened first. So, of course the backplate was chewed up and a metal chunk or two went up thru the bore and gouged the piston in a couple of places. Since we had no prior history on the engine, or how it was run, it could have been from excessively lean running and overheating with a lack of oil, or....
« Reply #6 on: March 21, 2025, 08:41:59 PM »
     I can't imagine, I have been doing model airplanes since the 60's to various degrees and I have never see anything like that. I've seen car parts that were about like that.
« Reply #7 on: March 23, 2025, 02:40:00 AM »
I don't have any background on this engine. So it may have been abused, and damage is not the result of poor quality. So I'm not faulting the manufacturer. It was purchased by a friend who wanted me to test it. It had a couple of scratches on the piston that I didn't like, and it didn't feel as loose as I thought it should. It didn't feel too bad, actually, so I was pretty disappointed when I popped off the backplate to inspect the insides.
One scenario is that the rod cracked first, and then the bearing spun. The oil holes in the bearing and the rod are rotated. And then, presumably as the engine kept running, perhaps screaming lean (or not), the bearing walked out of the rod on the cracked side towards the backplate. The backplate was really chewed, but it is surprising how much end clearance there must have been to start with. As far as why the rod might have cracked first, it might have been from a shaft run, or....? Heat may have been a factor, as the strength of aluminum falls off appreciable with temperature. I agree that this the kind of thing you see in R/C car engines, likely due to extreme rpm sometimes under no-load conditions, heat from a cowled application, and a really miniscule oil package in the fuel. I've seen the rod in a car engine split the length right up the centerline, which is an interesting failure mode.
Offline Daniel_Munro
« Reply #8 on: April 05, 2025, 07:43:28 PM »
I tried an Aviastar 46 about a decade ago. Was pretty much useless for stunt flying. The stock venturi was too small and restricted it from making useful power. I opened it up and it would start a flight at a nice setting but would run away and you’d be hanging on to the handle with two hands until it ran out of fuel.
Eventually I made it useful by running a finer pitched prop. But it was not ideal. Also had an RC version which was also useless. Terrible carb.
NZL7396
Offline richardm
« Reply #9 on: April 06, 2025, 08:10:46 PM »
I seem to have acquired a .53, guess I won't bother building anything special for it, might throw it in the mule and see ( Doodlebug)
« Last Edit: April 06, 2025, 10:41:41 PM by richardm »
Richard Mc Fadden
« Reply #10 on: April 07, 2025, 12:44:23 AM »
The chatter marks on the near edge of the rod look like somebody used one of those swivelling deburr tools. I have one or two in my rollaway downstairs. They're ok for holes, but I much preferred to use a smooth mill file to break edges on the parts I machined. Anyway, that makes me think that rod is machined from bar or plate, which is a good thing...unless they didn't pay attention to grain direction.  H^^ Steve
« Reply #11 on: April 07, 2025, 11:46:56 PM »
Steve,
The Aviastar .61 rod was definitely machined from plate or bar. The deburring was crude, but I doubt that a swiveling tool was used based on the appearance of the markings. That said, you'd have to really work at it to get the inconsistencies on the different edges....
Wrought aluminum is close enough to isotropic that you shouldn't have to worry about grain orientation. If you are trying to cut the factor of safety that close...well, good luck to you. This rod had some other problem, either in construction or operational abuse. The latter wouldn't surprise me.
« Reply #12 on: April 09, 2025, 08:40:39 PM »
Well, other than the crack and bushing problem and the crappy debur job, it looks like a nicely machined rod, CNC'd, without much doubt. Probably as nice or nicer than Super Tigre rods, in fact. I would guess they had too much press fit on the bushing and started the crack during assembly.
I made both commercial and Boeing parts, and sometimes Boeing drawings called out grain direction and sometimes they didn't. I recall getting a package for one commercial job, complete with sawed cold rolled steel blocks, but the drawing said "Any Aluminum". That's the kind of crap that made me cranky with the office nitwits, and finally got them to have the "planning" sent through the QC office for a double check. Still pretty iffy, with the guy we had in QC at the time. I worked 10 years in QC and hated every minute of it. Management looked at us as a hinderance and the shop guys thought we were rat bastards. Once I reached into a box of 100 small parts from an outside vendor, pulled one at random for a 100% inspection and that one was the only bad part in the box. How lucky was I!  LL~ Steve
« Reply #13 on: April 10, 2025, 09:36:43 PM »
Steve,
The place I often saw a directional grain callout was on formed sheet products. You could bend a slightly tighter bend radius across the rolled direction (grain) of the sheet. We tried not to go below the normal minimum bend radius when designing parts because on some parts with the processing involved it became difficult to be sure if it was oriented properly. All were aerospace parts and as far as I was concerned, high rel.  No need to embed field failures into the equipment. Once you head off into composites directionality is absolutely everything. And, the latest "craze" in printed parts has that issue and many more.
I was one of the "office nitwits" which you speak of. The QA guy could be our best friend when the pressure on the fab shop was ratcheted up too high. MIL-T-FD, buddy....
