  • July 12, 2025, 07:55:13 AM
Author Topic: Attaching muffler pressure to Uniflow vent?  (Read 4230 times)
Offline frank mccune
« on: August 22, 2020, 03:15:13 PM »
              Is this a good practice?
               Tia,
               Frank
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Attaching muffler pressure to Uniflow vent?
« Reply #1 on: August 24, 2020, 06:06:41 AM »
Hello Frank I think the accepted wisdom is not to do it (unless it helps!) . I think why not try something especially if it is not too critical , you have little to loose and you can change it back if it mucks up your run. Regards Gerald
« Reply #2 on: August 24, 2020, 09:17:16 AM »
       Hi:
        Thanks for the replies.
         It was also suggested that I connect the line coming from the muffler to the overflow and plug the Uniflow vent.  Am I correct in deducing that the tank is no longer a Uniflow but a conventual suction tank with muffler pressure?
           Tia,
            Frank McCune
Offline John Miller
« Reply #3 on: August 24, 2020, 12:26:55 PM »
Frank, you're correct about pressure to the overflow, and plugging the uiniflow. Might as well use an old style suction tank with muffler pressure.
I've heard reports of guys having issues with pressure on uniflow tanks. I believe a lot of problems arise from  what style of uniflow you use.
A standard metal uniflow tank has the uniflow fuel tank end soldered to the pickup line. This works fine, but are susceptible to several possible issues.
First, you will have to physically raise or lower the tank to adjust the run, upright, and inverted. If you don't have the room to move the tank, you can remove the back, and re-locate the uniflow end.
Second, Pointing the outside uniflow end into the airstream to take advantage of ram air pressure has it's own problems. Going into the wind, speed slows due to the force of the wind. For instance, 55 mph stunt airspeed + 15 mph head wind = 40 mph actual speed relative to the ground. Pressure goes up, and engine richens up, slowing your plane further. The opposite occurs on the downwind leg. This can cause your plane to speed up downwind.
Third, Attaching muffler pressure to the uniflow may be adversely affected by the location of the inside end of the uniflow. It's generally believed that the inside uniflow end should be 1/4" to 1/2" forward of the pickup end. Too close, and air bubbles can be sucked into the pickup. It's not well understood that the inside uniflow end can be much further forward, up to about the middle of the tank, and work as it should, without the chance of introducing air bubbles into the pick up.
Fourth, It mightr be best when using an unpressurized uiniflow tank to place the uniflow opening inside a protected, from varying ram air pressure, area inside the cowl, high enough so it won't siphon out the tank.
My preferences, and personal choice for uniflow tanks is the humble RC style clunk tank. I've used them on every plane, except one, (An Excalibur !, a Dick Mathis design) for the last 25 years. I'll try to locate my tank illustration, and post it here so you can get a better idea of what I do. Thanks to My late friend Allen Brickhaus who clued me into this style of tank.
Over the years, I've streamlined the concept to where it seems to work better. There are some real advantages. Let me list a few.
First, These are easily available, and come in usable sizes.
Second, They are lighter in weight, size for size, than metal tanks.
Third, Set up like mine, they are true clunk tanks. The uniflow is not affected by the movement of the clunk fuel pickup. If the uniflow is tied to the clunk, so it moves with it, The apparent height of the tank is constantly moving,up and down as the clunk moves up and down. Not a good thing and defiantly not running like a true uniflow. It also negates the next advantage.
Fourth, The uniflow inside end is moved to about the middle of the tank. It's designed to allow the apparent tank height to be changed by rotating the uniflow tube. This makes it easy to set the tank height without having to move the entire tank. With the uniflow end away from the pickup, muffler pressure works very well. Engine rpm remains constant up, and downwind.
Carefully study the illustration. This really works well.
John Miller
« Last Edit: August 25, 2020, 08:28:45 AM by John Miller »
« Reply #4 on: August 24, 2020, 01:20:05 PM »
       Hi:
         It was also suggested that I connect the line coming from the muffler to the overflow and plug the Uniflow vent.  Am I correct in deducing that the tank is no longer a Uniflow but a conventional suction tank with muffler pressure?
           Tia,
            Frank McCune
I agree with you.  A uniflow works with a slight vacuum that prevents the fuel pressure generated from G force from being transferred to the engine.
Adding muffler pressure completely blows the uniflow theory.
I believe that a tank with muffler pressure tends to go "a little" lean as the fuel is depleted, but the change is mitigated because the muffler pressure is more significant than the loss of fuel weight.
Offline Reptoid
« Reply #5 on: August 24, 2020, 11:09:02 PM »
While it still functions somewhat like a uniflo tank it is NOT the same. Uniflo venting (Like a sparklets water dispenser) is designed to equalize the atmospheric pressure at the fuel area surface and the outlet (needle valve on engine, spigot on water cooler. With muffler pressure you are increasing the pressure at the fuel surface in the tank to above ambient atmospheric (.5-1.5 PSI depending on muffler) but the atmospheric pressure at the outlet or needle valve is still at 1 atmosphere (ambient). This will effect the "break" or amount power changes with altitude and/or G load. In affect it will act like a slightly smaller venturi
       Don
       AMA # 3882
« Reply #6 on: August 25, 2020, 09:18:04 AM »
So with some luck you may see some sort of a better compensation with a pressurized standard tank.🦄
L
I have had success with Uniflow (set up ala John Miller's example from yesterday) with pressure both prop and muffler, and also with stock non-uniflow tanks both metal and plastic using muffler pressure alone.  I only had two remaining IC engines.  My OS46LA did not like uniflow at all.  It ran best on a stock clunk tank on muffler pressure outside the fuel cone.  My OS35s would not leave home without it.  Back in the day I ran crankcase pressure on my McCoy 35's with huge success but never uniflow.
Offline Reptoid
« Reply #7 on: August 25, 2020, 12:00:25 PM »
No, uniflow is still a uniflow, regardless of pressure.
Unless you want more power (bigger venturi), the flow rate in needle valve is still the same, and same fuel head pressure and replacement air pressure exist and the self regulating effect works.
Perhaps you see an interaction in wrong place? It’s typical for uniflow (without pressure) to go slightly richer towards end of flight when a non-uniflow does the opposite. It gets even more rich when you feed hot exhaust gases to tank. So with some luck you may see some sort of a better compensation with a pressurized standard tank.🦄
L
The reason a normal tank gets leaner gradually throughout the flight is the change in pressure differential is constantly changing as the fuel level (weight of fuel at centrifugal force) drops and the fuel is replaced by air at ambient pressure. A uniflo in flight has the same atmospheric pressure at the feed line and the vent line throughout the entire tank until the uniflo uncovers
You're arguing against very sound engineering principle, not with me. Your personal experience using muffler pressure may show little effect depending on venturi size, ambient barometric pressure and load on engine but it is NOT the same as no pressure. Imagine if you put 10-12 PSI from an air filled bladder into the uniflo vent. Will it run the same? No You will have to close the needle way down and there will be NO Break at all
       Don
       AMA # 3882
Online Massimo Rimoldi
« Reply #8 on: August 25, 2020, 01:48:06 PM »
Hi,
I believe you are talking about two different aspects of the problem.
1) the uniflow tank is a constant pressure tank, so the pressure at which the fuel comes out is constant until the uniflow pipe is discovered and this is independent of the presence or absence of a pumping system (if the system is constant)
2) the pressure with which the fuel exits (into the atmosphere) is equal to the difference between the pressure of the "pump" and the atmospheric one plus the pressure of the "column" of fuel present between the uniflow pipe and the sampling point, so if the pressure of the "pump" is higher than the atmospheric one, the effect will be like moving the tank inside the circle and/or moving the uniflow tube away from the external wall.
What I don't like about the uniflow+pressure system is that the pressure (taken from the muffler or from the crankcase) is not constant during the flight and therefore due to this the work of the tank is rendered useless (at least in part).
Massimo
« Reply #9 on: August 25, 2020, 02:10:11 PM »
This should give the idea
Offline John Miller
« Reply #10 on: August 26, 2020, 11:42:45 AM »
With a large amount of pressure that you refer to, 10-12 PSI, getting close to one full atmosphere (15 PSI), of course you'll likely have a run like a combat ship on a bladder. I don't believe that much pressure can be achieved with simple muffler pressure. In my experience, there's only a small boost in pressure. More importantly, the uniflow tank, running this kind of muffler pressure, is removed from the influence of real run variances, mainly from ram pressure, that occur when the model is going into the wind or down wind on the other side of the circle.
I'm currently running Stalker engines since the mid '90's. I also ran, and still do for certain models, OS fp's and LA's. I've used the tanks I've described since the '80's without the problems that are being described above. These of course are my own findings. Others may, for many reasons, not be having the same results.
For me, and others, who have tried tanks set up strictly as described, have found they work very well.
John Miller
« Reply #11 on: August 26, 2020, 01:52:54 PM »
  If you assume that the muffler pressure is a constant pressure source, it works exactly the same as a uniflow tank vented to the atmosphere, in that the outlet pressure stays constant regardless of fuel depth.  The pressure in the ullage is still reduced compared to the input by the hydrostatic pressure, even though the absolute pressure is above atmospheric, and the pressure at the outlet is higher than it would be vented to the atmosphere.
     That's the reason to use it  -which you largely have correct, it reduces the dependence on fuel draw, so you can increase the venturi size for the same run quality, or run the same venturi and get less pressure variation. The higher absolute pressure does have some other side effects - like, the needle opening has to be smaller - which can have some side effects. And also, you are heating the fuel, which *sometimes* makes it foam where it did not before, and "run away" lean at some point in the run. I have had that a few time, but have also run many, many successful (and constant-speed) flights with it, too.
      It's one of the 4 variants to try -
 straight uniflow (vent open and overflow plugged) - constant atmospheric pressure at outlet
 uniflow with pressure (pipe tap to vent and overflow plugged) - constant muffler pressure at outlet
suction with pressure (plug the uniflow and hook pressure to the overflow) - pressure varies with fuel depth, starts at hydrostatic + muffler pressure diminishing to muffler pressure at end
suction with open overflow (plug the uniflow and leave overflow open) - pressure various with fuel depth from hydrostatic pressure+atmospheric pressure, diminishing to atmospheric
   Note that the delta in the pressure from beginning to end with the uniflow is always the hydrostatic pressure, but that the absolute pressure is higher if you have muffler pressure, so your percentage change is smaller, which reduces the speed change from beginning to end.
Offline Reptoid
« Reply #12 on: August 27, 2020, 01:46:23 AM »
Technically in a standard uniflo set up there is a slight Vacuum at the outlet of the tank due to the suction of the venturi when the engine is running. That's what makes the fuel flow when the vent is at atmospheric pressure and the fuel is replaced by air as the fuel is consumed. When you pressurize the tank (By any means) it is no longer a "suction" fuel system; it is a pressure fuel system and it will affect the run regardless of where you inject the pressure. The amount of affect will depend on many variables: effective size of venturi (changes Vacuum) where you inject it (uni or std vent) How high the muffler pressure is, how tolerant your engine is to heated fuel with additional oil (Yeah you are in effect running burned exhaust residue including oil thru your engine) Might be beneficial if you're running a slightly large venturi or want to reduce the break.
My reference to applying 10-12 PSI was to clarify the differences not because I thought you could get that kind of pressure out of a muffler
       Don
       AMA # 3882
« Reply #13 on: August 27, 2020, 07:56:33 AM »
Never thought of that before.  Somehow I think it is very minimal but I am only guessing.  Another point of curiosity is why we do not use crankcase pressure.  I used it in the 70's on my McCoys and it really helped.  I am not advocating it, just curious.  I am sure there is a good reason.
Offline Peter in Fairfax, VA
« Reply #14 on: August 27, 2020, 10:06:35 AM »
Another question is why we don't use small one-way valves more.  For example, in a non-pressurized uniflow setup, the fill vent could be automated in this fashion, instead of the manual caps that are used. Even on a muffler pressure uniflow rig, siphoning the fuel into the low muffler of a profile is a common issue.  This seams to be mostly a "parts availability" situation, more so than a lack of interest.
« Reply #15 on: August 27, 2020, 10:36:00 AM »
 Sort of. Technically, a uniflow tank runs a constant feed pressure regardless of fuel depth. That can be at atmospheric pressure or muffler pressure, but it is unaffected by fuel depth. If the only thing going on was the outlet pressure, then, it would run the same setting throughout the flight, as opposed to suction tanks which go leaner as the fuel depth decreases.
   What is required to make the constant outlet pressure happen is a pressure differential between the pickup and the tank ullage equal to the hydrostatic pressure. If the vent pressure is atmospheric pressure, there is a slight vacuum in the ullage that increases with fuel depth. If the vent pressure is (contant) muffler pressure, it is a positive gauge pressure, but is still lower than the muffler pressure that changes with the fuel depth, since the hydrostatic pressure still opposes the pressure at the vent.
   The effect in either case is to run at a constant outlet pressure, which if nothing else happens, should keep the engine running at the same mixture and a constant RPM.
« Reply #16 on: August 27, 2020, 10:48:06 AM »
  I tried that -  the problem is that they leak air. It takes only a tiny leak to screw it up, because the air flow rate into a uniflow vent is extremely small - 6 ounces in 6 minutes.  Plenty of people use #60 vent holes and it provides absolutely no impediment to getting the air into the tank. It you try to use a 4-40 screw shoved into a piece of fuel tubing, it leaks air fast enough to start screwing up the uniflow - you need to seal up the threads with something.  So even the slightest leak into the overflow allows the pressure to rise in the ullage. The one-way valves are intended to stop fuel, not air, and everything leaks to some degree or another.
« Reply #17 on: August 27, 2020, 05:10:22 PM »
   It has been discussed over the years of using inserts of different inside diameters in muffler pressure lines to help avoid over pressurizing a fuel tank, not out of worry of bursting it, but trying for a more even run. When making fuel tank and fuel line plugs I always use something larger than the ID of the fuel line. When Windy mentioned using the pegs from the Lite Bright toys for that purpose, I rounded me up some and use those a lot.  They tend to glow a bit in the sun and makes them easy to find if you drop it. Ordinary BB's make a good plug for a fuel line, just stuff a couple up the short length of fuel line and it gives you something substantial to grab when pulling it off.
« Reply #18 on: August 27, 2020, 08:54:17 PM »
     Changing the diameter of the muffler tap, when hooked to the tank, makes virtually no difference in the supplied static pressure, at least over any practical range of restriction diameters. The pressure drop across the tap is related to the flow resistance, which is roughly goes as the square of the flow rate. The flow rate, into an otherwise sealed tank, is maybe 6 fluid ounces in 6 minutes - extremely slow. Any reasonable hole size will offer nearly no restriction to a hot gas at that low a flow rate. There are plenty of people running their engines with .040" vent holes with no problems, - hat's the same flow rate, but cool air instead of hot exhaust gas.
« Reply #19 on: August 30, 2020, 11:47:10 PM »
I once read, or was told, that the Asian engines seem to like muffler pressure, but others didn't. I have not tried it on a Euro engine or even Yankee engine. Randy Smith is against it, and I value his opinion, but I have always used muffler pressure on Magnum XLS .36 and OS .46LA with no problems, and like some things about it.
Keeps the bugs and little seeds out of the fuel filter, at the very least. I like that! I also pinch off the pressure hose a few times to lean the engine and help heat it up to running temp before setting the NV. Some don't heat the engine up, but just leave it set as per the last flight. I don't find that to work for me. I find a need to set the NV with a tach, and that setting changes from AM cool to PM heat, muffler pressure or not.
As Brett pointed out already the flow into the tank is relatively tiny...air or exhaust gas inflow is limited by the rate of fuel being burned off. It will NOT crap up your tank with exhaust residue.
The KEY THING, if you decide to try it, is to be VERY certain that your muffler will not come loose, the pressure tap is NOT going to come out, and the pressure tube and tank is NOT going to spring a leak. The result of any of these is a very lean engine, and that's NOT good. By the way, DO NOT use a muffler gasket. If you do and it blows out, it will be BAD for your engine.  Basically, if you struggle with mechanical issues like the above, don't do it. Not for everybody.  I tried pipe pressure on a .46VF, simply because the pipe was already setup for it (bought used), but I didn't like it at all. Not because it didn't run ok, but because fuel siphoned into the pipe and left me short of fuel a few times too many.  n1 Steve
