  • July 05, 2025, 05:24:33 AM
Author Topic: Armor all and how much?  (Read 2698 times)
Offline Tim Redelman
« on: December 29, 2013, 12:38:35 PM »
So I've been seeing some posts suggesting to add Armor All to your fuel to help stop fuel foaming. Is this a good thing to do or is this a bandaid for bigger problems. I've been flying R/C and C/L since I was 11 and have never heard of this. 48 now:-(
Tim
Re: Armor all and how much?
« Reply #1 on: December 29, 2013, 01:26:54 PM »
I decant my fuel from the gallon jug into a quart can (easier to carry around).  I add one capfull of Armorall (the Armorall cap) into a quart of fuel.  Seems to work OK.
Offline Jim Thomerson
« Reply #2 on: December 29, 2013, 02:52:40 PM »
I've never had much problem with fuel foaming, so have used it only a few times.  I add a drop or two to the jug and shake it.  Generally a very few drops will stop the foaming.
« Reply #3 on: December 29, 2013, 03:17:46 PM »
Hello Tim
               We use a spray bottle and give it two sprays to the gallon and  after that if you have a clear gallon you can shake it and will notice that it won`t foam. When I was flying R/C in the past we used to do it to the cool power 15% fuel we used and never had any problems.
Offline Brian Hampton
« Reply #4 on: December 29, 2013, 07:15:16 PM »
Armor All has been used in Australia for decades and generally all that's needed is one quick squirt into a gallon of fuel. There are stories floating around that it can foul plugs but I've never heard any Aussies complain and it's certainly never fouled any of my plugs.
« Reply #5 on: December 29, 2013, 07:48:34 PM »
Wow thats cool, Learn something new every day!
Tim
« Reply #6 on: December 30, 2013, 06:33:26 PM »
Obviously, too much doesn't seem to hurt anything.
« Reply #7 on: December 30, 2013, 06:59:37 PM »
  Au contraire, a link between the anti-foaming agent and plug taters is pretty solid at this point. I recommend using as little as possible and only if there is an issue. I use zero now.
« Reply #8 on: December 30, 2013, 08:03:15 PM »
Son of a Gun brand works just as well as Armor All. I've been using as little as possible, which amounts to at most, two drops to a quart. That usually makes it impossible to shake a foam into it. Any bubbles that do form when you shake it will disappear in a couple of seconds. I'm too worried about the aforementioned Taters to add more. If my profile has a super shaker for an engine, I make the tank pad out of a beer Koozie. and mount it with rubber bands rather than a metal strap.
Rusty
« Reply #9 on: December 30, 2013, 10:55:53 PM »
It was also reported that Armor-all had changed their formula and didn't have the magic ingredient anymore. But I wouldn't know about that, 'cause I've never put any in my fuel and never will. IMO, if you need it, you need to fix the problem, not put a Band-Aid on it. I did have a fuel foaming problem one time, and fixed it. I sure as heck wouldn't put that in my fuel as standard practise.  H^^ Steve
« Reply #10 on: December 31, 2013, 08:00:28 PM »
I tried an experiment some time ago to see what might happen so I put a huge amount of Armor All into a tank of fuel, I'd guess about the equivalent of enough for 100 gallons or more. The plug was still perfect about 10 minutes later when the tank was dry. I seem to recall the problem with taters had something to do with a particular brand of fuel used at that time. Steve is right though about the story with a a change of formulation and the magic ingredient (silicon) but I haven't checked to see if it's true because I still have my old (20+ yo) bottle of Armor All. It seems the silicon reduces the surface tension to a point where the largest bubble that can form is around 1mm diameter so presumably anything containing some silicon should work. I'd hesitate to use a bit of silicon car polish though :).
Offline Curare
« Reply #11 on: January 07, 2014, 04:47:27 PM »
Brian, if that's the case wouldn't pure silicon (like silicon spray) do the trick equally as well?
I've been using a spritz per gallon for years, and I've not noticed plug deterioration at all.
Greg Kowalski
AUS 36694
Offline Chris Wilson
« Reply #12 on: January 07, 2014, 06:50:43 PM »
Armour All seems to contain 'water based silicons.'
From their web site -
http://www.armorall.com/faqs/
"What are the ingredients in Armor All® Protectants? Do they include silicone, alcohol, ultraviolet inhibitors and petroleum distillates?
Armor All® Leather Care contains lanolin and natural moisturizers, and UV inhibitors. Armor All® Leather Care Protectant Spray and Leather Wipes contain water-based silicone emulsions, surfactants, and ultraviolet light inhibitors. Armor All® Original Shine Protectant contains water-based silicone emulsions, surfactants, and ultraviolet light inhibitors, humectants, dispersants and gloss enhancers. Armor All® Ultimate Clean Protectant contains water-based silicone emulsions, surfactants, ultraviolet light inhibitors and a fragrance."
But I am guessing that the surfactants play a huge role in reducing surface tension also.
MAAA AUS 73427
« Reply #13 on: January 21, 2014, 07:49:24 PM »
the "tater" problem seemed to be specific to a certain type of engine run.  If the motor was run in a two cycle and/or over heated and then quit rich they could form in one run.  Didn't seem to require Amorall either, although it seemed to be more common with it.  A healthy dose of castor oil in the fuel was enough to cause it at the end of a two cycle run.
