  • July 17, 2025, 05:58:42 PM
Author Topic: APC for PA40 UL?  (Read 2800 times)
Online Mike Scholtes
APC for PA40 UL?
« on: September 24, 2013, 02:30:18 PM »
With carbon 3-blades getting harder to find and staying expensive, is there a suitable APC prop for the PA40 UL? Model is 603-inch Oriental Plus, with carbon pipe. Not sure on finished weght but estimate 50-55 oz.
Online RandySmith
Re: APC for PA40 UL?
« Reply #1 on: September 25, 2013, 08:00:43 AM »
I would use a wood Zinger 11 x 4 Pro, or a Cyclone 11 x 4.5 , before I used an APC, both of those props have been used with great success
Offline Kim Mortimore
« Reply #2 on: September 28, 2013, 12:49:42 PM »
Mike,
I have a plethora of Cyclone 11 x 4.5 props.  Let me know if you would like for me to drop one in the mail to you.
Kim Mortimore
Santa Clara, CA
« Reply #3 on: October 01, 2013, 08:56:34 AM »
Hi Kim:
Don't  know how many come in a plethora but a kind offer nonetheless. I have one or two, and do have a couple of carbon 3-blades, but nothing lasts forever. I will keep your plethora in mind.
« Reply #4 on: October 12, 2013, 03:40:49 PM »
Mike I used the APC 11-4 on my RO Jett .40s for a couple years.  They worked fine.  Flew 60-64 ounce birds at about 10150 rpm launch.  The engine ( on pipe ) wouldn't be too different I don't think.
« Reply #5 on: October 12, 2013, 04:31:27 PM »
  I would also try a 11.75-4.25, which was originally designed for the PA40 (not UL).
« Reply #6 on: October 18, 2013, 04:39:07 PM »
Izzat an APC? It's not on their list, anyway. I'm looking for an 11.5" x 3.5 for my .46VF...need to get the launch rpm up about 500. I'm using a 12.25 x 3.75 cut to 11.5 and recarved into a scimitar. It works, but if I miss the rpm and launch at 10.4k instead of 10.45k/10.5k, it's not good. Likewise, if I launch at over 10.5k, it's not good. How do we know when an engine is underpropped? Or maybe it's the pipe length?
FWIW, I've often seen Randy Powell flying his PA .40UL on the TT 11x4.5, but using a muffler of his own design. I've heard from California that the TT prop also works very well on the Aero Tiger .36.  H^^ Steve
« Reply #7 on: October 18, 2013, 06:30:54 PM »
Steve,  you are saying 'not good' but not saying why or how.  What I and some others have done is to drop 'Rs' some, up pitch and pull the pipe out.  I've never run that engine but I'd try pulling the pipe back in 1/4" increments and then squeeze up the needle-or leave the needle and go up on pitch- not diameter.  I'm thinking 12" is nearly as far on dia. as I'd go on that.  If nothing else you'll get a good sense of how all the pipe, settings and pitch all work together on your particular set up. I fine tune pipe length to get equal lap times from start to finish of the run once the engine likes the setting and I've set the pitch to get the bite I'm happy with.
« Reply #8 on: October 18, 2013, 06:57:29 PM »
    That is an APC. I ran one at the 94 NATs. The 12.25-3.75 was invented to be a better match to a 46VF, the 11.75-4.25 was for the PA40 and worked well on the 40VF.
« Reply #9 on: October 18, 2013, 09:01:52 PM »
Dave...The current setup only gives me about 50 rpm leeway at launch between too slow, just right, and too fast. Can't see anything good about that. Needless to say, I'm pretty careful about getting it warmed up before I head to the handle. The .46 VF seems to want to run faster than I'm running it. Pipe length is set at 18.75", which looking at Randy's charts, may be too long? Exhaust timing should be stock at 145 deg., I believe. Pipe length has not been changed since I got the plane from Norm Whittle (his last IC model). It certainly seems too long, based on Randy's charts. Looks like I need to shorten the pipe quite a bit, but maybe I'm wrong?
To complicate things, this model only has clearance for 11.5" dia. I have a few 12" CF three bladers that are nominally 4" pitch...but I'd like to save them for next year's model, with a PA .51, rather than cut them to 11.5" and make them useless on the .51, since this season is over and done. Yet, when the weather is ok, I'd still like to fly this one, and also improve it for use as a backup next season.   H^^ Steve
« Reply #10 on: October 18, 2013, 09:36:37 PM »
Steve that does seem long.  The closest thing I have to compare to it are my RO .61 s where I'm using about  19" or a bit less on the pipe and maybe 9400 rpm tops, with anything from 12.25x 4.2-4.5 depending on which engine and weather. (3 blade Majic carbon).  I'd say maybe a start- over at say 18" on the pipe with a 12x4 something cut to 11 1/2" and try to be under 10k on the Rs.  I suspect your narrow acceptable range on the needle could be a Venturi that's too large for the load you have.  I'd guess a good place to start there might be .180 to .193 or less.  If you have another Venturi or can slip an aluminum tubing sleeve in the one you have to try it.... You are obviously in the band where the engine is jumping on and off the pipe.  I'm liking to stay on the front side of the pipe most always,  using the pipe more as muffler and backstop to rpm surges.  Some like the backside.  Either works but you can run slower on the front side and add some life to the engine if you try to run just a little slower and use more pitch.
« Last Edit: October 18, 2013, 09:59:44 PM by Dave_Trible »
