  • August 04, 2025, 11:39:52 PM
Author Topic: Engine mount bolt pattern listing?  (Read 853 times)
Offline Frank Clyma
« on: November 19, 2018, 10:30:48 AM »
Is there information available showing which engines use the same mounting bolt pattern? Especially for glow engines in the .15 to .46 range, for both currently available and older engines. I'm working on reviving an old Fancy Pants with a K&B 28, and may have to replace the engine. I don't like drilling new holes if there is a reasonable way to avoid that.
Frank
Re: Engine mount bolt pattern listing?
« Reply #1 on: November 20, 2018, 12:39:31 PM »
There used to be such a listing, but doubt that it still exists. I'd check the Tulsa Glue Dobber's site and if it doesn't exist there, it's unlikely you'll find it.  :P Steve
Offline Frank Clyma
« Reply #2 on: November 25, 2018, 07:28:29 PM »
Appreciate the post. Haven't found what I was looking for, but found a lot of other interesting stuff on the Tulsa site. (I didn't know about the TGD website.)
Frank Clyma
