  • June 20, 2025, 01:33:05 AM
Author Topic: Benoil mix, is this a good mix for engines?  (Read 1421 times)
Offline frank mccune
« on: June 17, 2017, 08:44:14 AM »
    Hello Again:
    I mixed a container of Benoil 3-1 with alky and added 5 percent nitro.  I used this in an old OS .35 S and it appeared to work well.  I did notice that the airplane was very easy to clean after the day ended.  The exhaust residue was very clear and the engine appeared to have been run in a cool condition with proper lubrication. The engine was run in the traditional 4-2-4 fashion with very little to no exhaust smoke.
    What is Benoil? The container stated that it was a blend of castor and synthetic.  How much of each is a unknown.  To be safe, perhaps I should add a bit of castor to be safe when using it in older cast iron/steel and plain bearing engines.
     Suggestions/comments.
        Tia,
        Frank McCune
Re: Benoil mix, is this a good mix for engines?
« Reply #1 on: June 17, 2017, 10:01:52 AM »
no smoke is trouble, I would add  5  ounces of castor  to your  23% oil mix, that will get it up  around 27% , your motor will like it better.  but what would be better  is to use a half castor half synthetic  28% oil  fuel  with  5 or 10 % nitro, whatever you  need  at the time
« Reply #2 on: June 17, 2017, 01:33:13 PM »
       Hello All:
       No smoke from a two cycle.  I have been running a brand of oil that is made for two cycle engines except marine engines that is all synthetic.  All of my 1970's 2 cycle Lawn Boy mowers do not make any smoke with this new oil.  The 1971 model is designed to use a 16-1 mix and it produced a large amount of smoke with the previous oils that I had been using.
     Back in the day, I was taught that the cause of smoke from a 2 cycle engine was caused by the failure of the oil.  It burned as it was in use which was a sign that the oil was not suited for the task.  Perhaps the new synthetic oils burn at a much higher temperature and are left after the combustion process to protect the engine.  Of course this information is about 50 years old. Lol
        Thanks for the replies,
        Frank McCune
« Reply #3 on: June 17, 2017, 02:11:49 PM »
       Hello All:
        Frank McCune
you were taught  Absolutely Wrong... especially when it comes to model engines running in a 4 cycle, but feel free  to run your mix
