Yep(on the scratches lining up)
Some times you just gota do it though.
When I was young and the mind and body not so numb I could feel when the sleeve was back in the right position.
A little off one way or another and the friction was very slightly more.
Couldn't do that today if I had to.
Sometimes putting the piston 3/4 of the way or so up hole and then while holding cylinder vertical move/rotate sleeve until gravity makes piston move.
Both ways are maybe got it, maybe not got it!
Marking/indexing sleeve to case will not quite get it right.
Just have to do what we have to do and run em.
Have been told about expanding pistons and then refitting but never tried it.
I do try to save all old pistons and Sleeves for later polishing and mix and match until decent fits are found.
This seems to be a requirement for Foxes, Even mixing new stuff to get good fits.
