Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 08, 2025, 01:52:04 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
angle of sprinkler hole-spray in venturi?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: angle of sprinkler hole-spray in venturi? (Read 3335 times)
Louis Keller, Jr.
Trade Count:
0
Lieutenant
on:
October 09, 2011, 12:50:07 PM »
Put some replacement parts in an os 35-s. All is good and it runs great on the bench. Curious though, does the angle of spray into the venturi make a difference in the run of an engine and if so how? I've always kept them pointing down at the same angle of the venturi-carb base. What's best?
Logged
Chris Wilson
Trade Count:
0
Admiral
Re: angle of sprinkler hole-spray in venturi?
Reply #1 on:
October 09, 2011, 04:04:49 PM »
Rotate the spray bar so that the hole just disappears from view, that is the region of highest velocity and lowest pressure without suffering from any direct ram air effects.
Having it pointed straight down the throat of the venturi will place it into a turbulent area and may give inconsistent results.
Last Edit: October 09, 2011, 04:26:40 PM by Chris Wilson
Logged
MAAA AUS 73427
Nothing in life is so exhilarating as to be shot at without result. It's not enough that we do our best; sometimes we have to do what's required
scott matthews
Trade Count:
0
Commander
Reply #2 on:
October 11, 2011, 07:12:37 PM »
After watching this post for 3 days I am assuming that this answer is totally correct? There are no differant opinions?
Logged
Chris Wilson
Trade Count:
0
Admiral
Reply #3 on:
October 11, 2011, 07:55:13 PM »
There are always other opinions mate but please view -
http://www.clacro.de/
Go to 'design/ venturis' and check out sketch 6B.
Last Edit: October 11, 2011, 08:21:50 PM by Chris Wilson
Logged
MAAA AUS 73427
Louis Keller, Jr.
Trade Count:
0
Lieutenant
Reply #4 on:
October 11, 2011, 08:32:44 PM »
thanks fellas. Great info. will put to practice next session.
Logged
Chris Wilson
Trade Count:
0
Admiral
Reply #5 on:
October 13, 2011, 03:51:58 PM »
This quote sums it up VERY well -
"Using a manometer an an appropriate source of moving air, you will find that when rotating the spray bar in the venturi that draw is essentially constant when the hole is out of sight, and will bump up by about 15% when it is positioned in the exact right spot."
From -
http://controlline.org.uk/phpBB2/viewtopic.php?t=5236&highlight=
(second last post on page one.)
Cheers.
Still learning after 50 years.
Logged
MAAA AUS 73427
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Reply #6 on:
November 01, 2011, 10:38:51 AM »
Hi Chris,
Thanks for the info. For what it's worth, I have always angled it slightly to the rear from vertical, just OOS. This has always seemed to work great for 4-2 engines.
Big Bear
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Gene O'Keefe
2014 Supporters
Trade Count:
0
Captain
Reply #7 on:
November 01, 2011, 12:27:43 PM »
I concur with Bill...to the REAR just out of sight vs rotating it to the front.
Logged
Gene O'Keefe
AMA 28386
Print
Pages: [
1
Go Up
« previous
next »
engines
open forum
basis
tuning
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
