  • July 20, 2025, 01:16:30 AM
Author Topic: Aluminum ring on cranshaft balance  (Read 1092 times)
Offline Ty Marcucci
« on: July 02, 2017, 12:45:23 PM »
At a contest earlier this spring, I had my ST .46,  on my P51-B,  stop suddenly in flight during Profile.  Later it just would not start. Looking back I'm glad I turned down the use of an electric starter. Finally, last week, I removed the back plate, head, etc.   It was then I found several small pieces of aluminum all bent up in the engine.   I removed the back plate on another ST .46 and there it was.  That too has been removed. So, if you have an ST .46, or even a .60 the older G21 or V series, you may want to investigate and see it the ring is still in place.  H^^
« Last Edit: July 31, 2017, 10:10:07 AM by Ty Marcucci »
Ty Marcucci
Offline pmackenzie
  • Pat MacKenzie
Re: Aluminum ring on cranshaft balance
« Reply #1 on: July 02, 2017, 12:49:19 PM »
Pretty sure it was done to reduce the volume of the crankcase.
At least that was the theory at the time. Rossi's had it as well.
The grooves in the crank are the volume reductions to produce the counterweight.
MAAC 8177
« Reply #2 on: July 02, 2017, 01:40:13 PM »
I have heard or the ring, but never have I seen one. I removed the back plate on another ST .46 and there it was.  That too has been removed. So, if you have an ST .46, or even a .60 the older G21 or V series, you may want to investigate and see it the ring is still in place.
Can anyone explain why it was ever on there?  I noticed the balance (counter weight) had grooves in it, to hold oil?  A search came up with nothing.  D>K
   It was there to "fill up space" that would otherwise have been open around the crankpin side. I had never seen one of these fail, but Eric Viglione pointed out a few examples. There were are least three types of crank, the "porkchop" (that has cutaways on either side of the crankpin), the "full circle" (that is the porkchop, with added "gussets", maybe to make the crank stronger {why, I have no idea, the crank itself was plenty strong enough}), and then the "full circle with stuffer ring" that ou have. The purpose was to "stuff" the crankcase and probably reduce the oil drag - again, for no good reason I could see, even for R/C.
    As you found, the stuffer ring occasionally comes off. I now recommend cutting it off before it falls off on its own, one of the few engine modifications I would make  a priori, just as a reliability change.
     The "porkchop" crank was reputed to be the one to have back in the day, but any difference it might have made was entirely and utterly swamped by the quality of the ring you wound up with. People have taken either of the full circle versions and ground off the gussets to make them porkchop style. I never saw that make any difference, but the people who did stuff like that were usually so far down the rabbit hole already that you really couldn't separate out the changes.
Online Steve Helmick
Re: Aluminum ring on crankshaft balance
« Reply #3 on: July 02, 2017, 07:27:16 PM »
K&B Series '61 > ??? (their high performance engines) originally had the aluminum ring around the crankshaft counterweight, also to "stuff" the crankcase. They also gave problems, and the standard fix was to cut it off. While doing that, I'd expect that the webs would be removed to "improve" the balance, whether it helped or not.
I suppose my multiple ST G.15's, G.21 .29rv's and single G.65rv also had rings around the crank balance, but I am not 100% sure. I am sure that I never had any problems with that particular feature, tho it is pretty obvious that an aluminum ring would tend to expand more than the steel crank, and would therefore be fairly likely to come adrift. The K&B .40 that I was involved with for Rat Racing also never had that problem, while the Series '61>'64 .35's I flew in Combat had so many problems (anything that could go wrong, usually did), one more would have hardly caused a raised eyebrow. LL~ Steve
