  • June 19, 2025, 07:40:25 PM
Author Topic: O S L A 46  (Read 5254 times)
Offline Bootlegger
O S L A 46
« on: April 01, 2017, 08:58:55 AM »
 I am running an L A 46 on 2.5 nitro and 22 oil half/half and only getting 5.5 min of run time on 4 ounces.  My next step is changing glo plug, then venture, as this one is .281 all this is with a tounge muffler and 11x4 apc prop.
  Any other suggestions/help/ideas???
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Fredvon4
  • Central Texas
Re: O S L A 46
« Reply #1 on: April 01, 2017, 10:04:34 AM »
Gil
I assume you need longer run time from the "only getting 5.5 min" blurb
Most folks are going to ask what plane, what tank configuration, what length lines, what lap times, how many more laps do you need...
Some will say add Coleman fuel, at least one will say Acetone is better...most will tell you what you know....bigger tank or custom tank
Fred von Gortler IV
Re: O S L A 46
« Reply #2 on: April 01, 2017, 10:27:57 AM »
I dont get what the dilema is here, if you need more fuel add more fuel,
are you getting the run you want every time? aside from time?
then build a bigger tank, changing anything will change the run
Online Gerald Arana
Re: O S L A 46
« Reply #3 on: April 01, 2017, 12:34:44 PM »
Gil,
My personal set up for the LA 46 is: 6 MM venturi. That is the one for the LA 25. I don't know what the decimal equivalent is. (Comes with a 7 MM venturi)
A 762 muffler, UNALTERED! Yes, it has a very small exhaust hole and that is IMO what gives me a 3-3/4 oz. run for the complete pattern. (At sea level)
I use a Vess (wood) 11 X 4 and 10/22 fuel. I have not had a problem with lack of power.
That's my set up and I'm sticking to it! y1
Jerry
Re: O S L A 46
« Reply #4 on: April 01, 2017, 02:54:47 PM »
Gil,
     The stock 25LA venturi is 6.5mm/~0.257. If you are really using 6mm/.236, then that would be a substantially smaller venturi and use a lot less fuel. 7mm/.276 with the stock spraybar is pretty darn big, well outside the usual sweet spot range. 6.5/.257 is right down the middle, so I would expect that to work very well.
     While I have thrashed the smaller engines extensively, I have never run the 46LA myself. All I know about it is observation from others and a general rules of thumb. I do know that if I had to choose between an ST46 (which I know very well) and a 46LA, I would choose the 46LA for sure.
« Last Edit: April 01, 2017, 09:32:03 PM by Brett Buck »
Online Gerald Arana
Re: O S L A 46
« Reply #5 on: April 01, 2017, 05:52:44 PM »
Brett, It is the stock one so I guess it it is 6.5 MM
Thanks for clarifying that for me.
Jerry
Online Gerald Arana
Re: O S L A 46
« Reply #6 on: April 01, 2017, 05:54:11 PM »
Put on an 11-5 prop, that will give you more mileage.
MM, an 11 X 5 gives me to much speed. I'm doing a 5.2-4 lap now. Why change????
Jerry
Re: O S L A 46
« Reply #7 on: April 01, 2017, 09:39:59 PM »
   A Gerry notes, that seems like it going to go WAY too fast, or the engine will have to backed off too far to produce full power. I think the setup he describes is the way to go, and build a bigger tank to get the desired run time.  Even a Supertigre would need at least 5 ounces even on 5% and stock venturi.
Online Geoff Goodworth
Re: O S L A 46
« Reply #8 on: April 01, 2017, 11:18:40 PM »
Brett's comment about the FP 20/25 venturi ID is on the money.
I've converted quite a few FP 20s and FP 25s and all my venturis came from Tower. Despite what the technical notes on the web site say, all of mine have measured 6.55mm using a vernier caliper that has never been dropped.
I've seen an LA 46 in a Heartbeat Models Sukhoi run very nicely using the 6.75mm venturi—the small venturi from the days when the FP 35/40 came with two venturis.
My very porky—57 oz—Shoestring designed around the Brodak P-40 wing—needed the 7.1mm stock venturi using the APC 12.25 x 3.75 prop and fuel with 22% oil, 50/50 blue Coolpower and castor, and no nitro. I tried it with a 6.75mm venturi but changed up because the engine seemed to labour. The muffler was a Thunder Tiger GP 40 item—very similar to the OS 3020 with a 9.5mm outlet.
Also, I ream out the FP 20/25 venturi to 6.75mm. It's only 0.008" so I don't change anything else. If I needed more ID I would change the bell mouth slightly.
For reference, my ARF Cardinal has an ABN FP 40 with a 6.75mm venturi and a Zambelli-spec hemi head. It runs a Bolly Clubman 11.6 x 5 and the same 22%-oil fuel.
Offline Chris Belcher
Re: O S L A 46
« Reply #9 on: April 03, 2017, 02:21:23 PM »
My LA46s will do 7 minutes on less than 4 ozs. Try a .272 venturi with a tigre needle valve assy and 5% with a Xoar 11 x 4 prop and run it a little under peak RPM...10,000 if I remember. I know the choke area is small but it still has plenty o power and never "breaks"...just a steady wettish 2. I mod these to 4-2 by raising the intake ports and they still do 7 minutes on a little OVER 4 ozs so yours should be doing the full pattern on 4 ozs...unless you have an actual fuel leak somewhere, but that would probably cause all kinds of leaning and fattening I have seen tanks start siphoning and the pilot is unaware, so one thinks he has 4 ozs but by the time you get to the lines...not so much.
Re: O S L A 46
« Reply #10 on: April 04, 2017, 01:43:53 PM »
What  Needle Valve assembly  are  you  using?
Offline Bootlegger
Re: O S L A 46
« Reply #11 on: April 04, 2017, 02:20:36 PM »
P A 40 from Randy Smith, do you know him???      y1 <= #^
Gil Causey
AMA# 6964
Re: O S L A 46
« Reply #12 on: April 04, 2017, 05:06:34 PM »
hmmmmm   I would listen to him !
Offline Allan Perret
  • Proverbs
Re: O S L A 46
« Reply #13 on: April 07, 2017, 02:21:16 PM »
5oz tank
Allan Perret
AMA 302406
Slidell, Louisiana
Re: O S L A 46
« Reply #14 on: April 07, 2017, 07:24:41 PM »
Yep, that bar is .157 , and  your  4  0z  is normal, I would try  4  1/2  ounces. that should get you a complete pattern  easy.
If for some reason   NO  then  use  4 3/4  to 5,   This is  not  too much fuel for the  OS 46
Re: O S L A 46
« Reply #15 on: April 07, 2017, 07:40:41 PM »
   I'll never understand the fascination with getting "great fuel economy" on a stunt engine! If you have a OS LA.46 that is using less than four ounces for the pattern, you aren't getting all the available power out of the engine. Yes, you can detune the engine to fit special circumstances but there are other ways to do this than by strangling down the engine. if you need to choke it down that much, you might want to consider a smaller displacement engine. Everything from the engine start, through the flight and shut off is more predictable and consistent, I think, when the engine can eat and breath like it needs to. Fuel is power and cooling. I like to get all I can of each.
Offline Dennis Moritz
Re: O S L A 46
« Reply #16 on: April 08, 2017, 09:08:34 PM »
I used an excellent running LA46 on a kit bashed Tanager. Stock venturi, tongue muffler and an FP needle valve. 12.25x3.75 APC. Ran it very rich. Broke mildly at the top of loops and top of vertical maneuvers. Broke in overhead eight. Flew near 6 second laps, somehow, staying out on the lines. A friend didn't believe how slow it flew. So we timed it. Engine burned every bit of 6 ounces in a clunk tank.
