  • June 21, 2025, 02:43:30 AM
Author Topic: Stuck Motors  (Read 1458 times)
Offline Shawn Kuntz
  • Ringmasters Forever!
Stuck Motors
« on: February 27, 2007, 09:33:51 AM »
What is the best way to clean up old motors that are gummed up and don't turn over?  I have a few old motors...McCoy Redhead, Torpedo 19, and two Johnson 35's.  I would really like to clean these up without damaging them.
Shawn Kuntz
Bismarck, North Dakota USA
Re: Stuck Motors
« Reply #1 on: February 27, 2007, 09:41:37 AM »
Hi Shawn,
The most popular methid is using a crock pot, and full strength antifreeze.  Soak a day or two and good to go.  (IT WILL remove the paint from the McCoys and K&Bs)
My favorite is boiling them in dishwasher detergent (not "dishwashing") for 20-30 minutes.  Some say that this discolors the engines.  I have not had a problem using "DISHWASHER" *soap* either liquid or powder.
A lot of the time I simply break then down and clean them by hand, if they are not REAL bad.
Whatever you do, check the wrist pin and make sure it isn't stuck when you put it all back together.  I use a, pretty much, 50-50 mix of airtool oil and Rislone to reassemble everything.
Bill <><
Offline Bill Gruby
Re: Stuck Motors
« Reply #2 on: February 27, 2007, 10:42:08 AM »
FWIW------In case you missed it in your other thread, according to (AMEE) the green finish on the Johnson is not annodized it is painted, be careful the crock pot may remove it.
"Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
Offline Shawn Kuntz
Re: Stuck Motors
« Reply #3 on: February 27, 2007, 10:51:41 AM »
I definately don't want to remove the green finish.  How about boiling this in hot water with dishwasher detergant?  Will that take the green off?
Shawn Kuntz
Re: Stuck Motors
« Reply #4 on: February 27, 2007, 10:53:18 AM »
Pretty sure it will, too.  It took the red off my McCoys real nice!  Of course, the McCoy Red is an easy fix.
Online RandySmith
Re: Stuck Motors
« Reply #5 on: February 27, 2007, 10:55:13 AM »
Hi Shawn
You may do better to take off the backplate  and  use  WD 40 and or fuel. many times you can free up the stuck motor with this  or  spray penetrating oil spray in it, This way you dont swell gaskets or remove the paint
And with plain bearing engines you don't have to worry about old ball bearing corrosion.
After you have it clean you can wash it with dish detergent  then  re oil it
Re: Stuck Motors
« Reply #6 on: February 27, 2007, 05:32:28 PM »
I have had good success by heating the engine with a heat gun, or even a hair dryer, and with a prop installed, just keep working it back and forth untill it frees up. You do want to make sure that rod is not stuck on the wristpin, as most stuck engines seem to have this problem. Generally you can take the back plate off and see that the rod will move back and forth on the wristpin. The heat also will let you take stuff apart that is stuck like heads to cylinders, where asbestos gaskets were used.
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
Re: Stuck Motors
« Reply #7 on: February 27, 2007, 05:57:23 PM »
Same here, Heat gun has worked well for me. I dont have a crock pot and my wife wont let me use hers, so I tried the heat gun on a few old ones and it worked a treat. Just have to be careful not to burn the fingers. ouch!  I usually add a bit of glow fuel once it starts to move, and I find it frees up very quickly from there.
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Alan Hahn
Re: Stuck Motors
« Reply #8 on: February 28, 2007, 05:28:45 AM »
Warren,
I respect your wife's judgement!  mw~ Don't use her crockpot. Once we put the antifreeze in it isn't safe for cooking.  :X
Now I bet you knew this and were just having some fun with us.
Offline Bootlegger
Re: Stuck Motors
« Reply #9 on: March 03, 2007, 07:50:53 AM »
 Something else that might help is to " Warm up" the engine using a hair dryer or $ cote gun. I have gotten wrist pins freed up doing this.
 Charly Melancon showed me this trick as well as many others... H^^ D>K D>K H^^..........Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Russell Shaffer
Re: Stuck Motors
« Reply #10 on: March 03, 2007, 06:32:33 PM »
Used your ideas today on a Veco 45 I got from Clint.  It was stuck so I heated it and soaked it in laquer thinner.  After it broke loose it was rough, so tore it down and cleaned out the internals.  The wrist pin was well and truely stuck, but the heat gun freed it up.  All back together and it runs a good 2 stroke with an old Toronado 12-6 that is probably way too much prop.  4 ounces of fuel seems to have smoothed out all of the rough feelings.
Russell Shaffer
Klamath Falls, Oregon
Re: Stuck Motors
« Reply #11 on: March 03, 2007, 08:39:13 PM »
Glad the heat gun worked for you Russell. You also did the right thing by tearing it down and cleaning it out. Thanks for letting us know.
Re: Stuck Motors
« Reply #12 on: March 03, 2007, 10:43:46 PM »
Wouldn't have done it without the good advice from you guys.  Thanks.
Russell Shaffer
