  • June 15, 2025, 10:25:52 AM
Author Topic: After run care for fully cowled muffler equipped engine?  (Read 1395 times)
Offline frank mccune
« on: May 11, 2023, 05:50:06 PM »
      How is this done?
      Frank’s
Re: After run care for fully cowled muffler equipped engine?
« Reply #1 on: May 11, 2023, 06:38:59 PM »
In any case you'd surely have access to the the venturi,  lest the engine couldn't run.  Shoot some Mystery oil or air tool oil down the venturi and flip it through several times.  That should do it.
« Reply #2 on: May 12, 2023, 07:54:23 AM »
     Hello Dave:
     Thanks for prompt reply.  That sounds simple enough.  I will try to do that.
     Stay well,
     Frank
« Reply #3 on: May 12, 2023, 01:54:24 PM »
The old Doc will make it even simpler as I will pull the glow plug also and put some oil through the plug hole. D>K
now I await the notice of a small donation to SH. S?P
