On the other hand, secondary parts, like the prop driver, can easily be made by someone who can operate a lathe, maybe not worth the trouble to try to source them from Ukraine.
This is the problem - instead of getting parts, you have someone make them? If you took a drawing to a machine shop to make such a thing, the cost would be astronomical and there would be a good chance it would be wrong. To ensure success you would need to take it to a specialty machine shop, still more expensive. A custom one-off part with the required tolerances would be, I would guess, $500 minimum, maybe a lot more depending on whether a CAD drawing and CAM machine programming was required.
That's one reason I never got involved with the Retros, even though I am impressed with the performance. No reliable suppliers, including (no offense) the Yatsenkos themselves.
