Engine basics => Engine set up tips => Topic started by: bob branch on June 22, 2006, 07:30:42 PM
Can anyone tell me if the Aerotiger .36 mounting holes match up with the Brodak .40 holes? What about lengths to the spinner backplate?
thanks,
bob branch
Same as the ROJett .40 BSE!! #^ ;)
Curt
The Brodak 40 is a "drop in" replacement for the OS Max S 35. The holes do not line up with the Aero Tiger - the Brodak fore to aft spacing is about 1/8" longer. The shaft on the Areo Tiger is also a bit longer. If you align the forward mount holes, it is almost 1/4" longer than the Brodak to the back of the prop.
The AERO Tiger
Is the same mount as a Thunder tiger 36
Magnum 32 - 36
OS 32
And most ALL of the small case Heli Motors
Regards
